Old 03-04-2009, 05:18 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Power steering pump bad?
How do you know the power steering pump is going bad? In my case, the steering works fine, but when I start my car up in the morning..especially on a cold day, the pump is very loud, whiney...as if a bearing is bad? It quiets down when it warms up, but is this my pump starting to fail? I can't imagine the o-ring would have anything to do with it....
Any suggestions?
thanks,
1995 Subaru Svx L / AWD
Old 03-04-2009, 05:25 AM
Re: Power steering pump bad?
There's a very good "How to" on this site for rebuilding the pump, quite a simple task.
The O-ring issue usually causes leaks or stiffness in the steering from air getting in.
Old 03-04-2009, 06:36 AM
At the risk of stating the obvious, is the fluid level full?
Old 03-04-2009, 07:00 AM
msvx95's Avatar
It's just a phase
yes it's in the range it needs to be when it's hot and when it's cold.
Old 03-04-2009, 08:49 AM
jdmlambo jdmlambo is offline
Funny you say that...my dad and i have svxs...and his is doing exactly what yours is... it will quiet down after a little bit....but loud on start up.. his fluid was full but it was foamy...
This is telling me there is air in the system....the bad 0-ring will allow air into the system.. the air, mixed with the cold, mixed with probably old fluid.. Thatll whine.. before i change the pump, im going to rplace the o-ring for a buck and flush the thing... read some stories about the o-ring with some happy endings...
if your fluid is full and clean, no air or leaks.... replace the pump..
Old 03-04-2009, 09:30 AM
msvx95's Avatar
It's just a phase
i'll have to look at the fluid and see....perhaps the o-ring needs to be changed. I just wish the weather would warm up so I can do this.
Old 03-04-2009, 10:53 AM
laserx's Avatar
laserx laserx is offline
I can and have felt your pain with this miserable cold winter...my SVX won't start the other morning and my son and I would have to run back into the house every few minutes to warm up . Just imagine how cold it would be without "global warming". My son will be taking mine to the garage he works as a mechanic for Canadian Tire, I'm hoping this will fix my pump issues.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake.
Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB
Koni struts/ground control coilovers
Stainless steel brake lines
K&N filter, custom front grill
H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w
Clear front and corner lens
Old 03-05-2009, 05:23 AM
msvx95's Avatar
It's just a phase
I may have a small leak in the pump...fluid level was low this morning, but can't see any puddles under the car...My high pressure hose may have a leaky fitting too. I need to kind of wait for the weather to get a tad warmer so I can do some maintenance on it.
Old 03-06-2009, 12:02 AM
I would bet my last $$ that it is the O-ring. If change it, I would be shocked if it didn't fix your problem.
