Old 12-29-2008, 08:39 PM
knowtion knowtion is offline
To rebuild or not to rebuild ?
Would you reccomend rebuilding the tranny for a 92 SVX or sourcing a low mileage used tranny.
I hear that the MPV, Pathfinder, and Legacy trannys are the same, is there a specific tranny that is the best to swap in ?
I'm not going to do a 5 speed conversion, unless I get a new daily driver car.
I have a mechanic who specializes in rebuilding trannys and he really wants to rebuild this one. I know the early SVX trannys just plain suck but he sure makes a rebuild sound good.
Old 12-29-2008, 09:19 PM
kwren's Avatar
kwren kwren is offline
Re: To rebuild or not to rebuild ?
He could be great and still have no clue what updates-etc are needed for an SVX transmission.
I would probably shoot for a lo miles used one if going for the Subaru company rebuilt doesn't fit your budget.
I had real good luck with lo mileage engines and transmissions on my 90 legacy.
Not familiar with other transmissions that will bolt right in but there are very knowledgeable people on this form!
Good luck,
Keith
Old 12-29-2008, 09:43 PM
Thanks, yeah i was hoping to find someone who has done a proper rebuild who can fill me in as to what I will need and need to know. I'm sure we could get a nice rebuild if I get the right info on here.
I can't seem to find a thread on someone's rebuild experience.
Old 12-29-2008, 09:46 PM
Just to clarify, they use the same transmission planetaries and clutch sets... The cases for the transmissions in the pathfinders etc.. are very different.
Old 12-30-2008, 06:36 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Again, you could just get a nice low milage used 4.44 or 4.11 transmission you know.. Gives you more of a kick..
Old 12-30-2008, 11:14 AM
dcarrb dcarrb is offline
If this is a competent guy (or gal) who will give you an up-front (and reasonably competitive) quote, stand behind the work and not take six months getting it done, I'd probably go this route.
dcb
Old 12-30-2008, 02:38 PM
Where would I pull one of those from? Legacy ?
Old 12-30-2008, 02:43 PM
Freeman's Avatar
Unregistered User
Yep!
Click here
The link above is OT's(svxfiles) info on it..
Old 12-30-2008, 02:47 PM
I believe any 1992-'97 Subaru automatic will do (someone please correct me if I'm wrong), but you'll also have to change the rear gear as the final drive ratio won't be the same. A search will unearth the specifics you need.
Remember that "more kick" also means shorter legs on the highway.
I'm afraid it won't be too long before there are no more SVX reman transmissions to be had off the shelf.
dcb
Old 01-01-2009, 08:50 PM
Thank you for that link Freeman, muchly appreciated.
I am thinking I will try to find a broken legacy tranny and have that rebuilt and hope that my current original tranny lasts in the mean time.
Does anyone know if I need a Legacy "outback" model tranny or just any legacy will do?
Also wondering if a Legacy tranny from a 98 is a 'Phase 2' which would be more tricky ?
Also, if I install a Legacy tranmission then I wouldn't be able to install the SVX "Quick Change Shift Kit" or would I
Old 01-01-2009, 09:05 PM
The phase II transmissions are a ton of work. Young Tom(TomsSVX) was working on one and said its a way too many hours working with all of the wiring alone...
http://www.subaru-svx.net/forum/showthread.php?t=47098
Just find a lower mileage transmission out of another suby(junkyard), it doesn't matter if it is a outback model or not, just has to be a phase I and don't bother having it rebuilt as those aren't prone to failure in the way that our transmissions are. Also as stated get the matching rearend.
With a 4.44 or 4.11 transmission, the quick change is not necessary. In the Svx transmission it is made to have long, smooth shifts whereas the other suby transmissions all have quick, sporty shifts. This is the main reason ours wear out quicker-caused more heat/more wear on the clutch packs.
Edit: if your mechanic will give you a great price on a 4.44 or 4.11 rebuild, then go ahead, otherwise its not necessary.
Old 01-02-2009, 06:31 AM
sicksubie's Avatar
Some 1998's will work, I just finished swapping in a 4.44 trans from a 98 legacy outback. You just need to make sure it does not have the spin-on filter on the side of the tranny housing.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-02-2009, 03:43 PM
oab_au oab_au is offline
Not so, all the boxes work the same way.
Its the programing in the TCU that provides the slow smooth change. Any auto that you put in, that uses the SVX TCU, will have the same slow change, that the Quick Change removes.
One Arm Bloke.
Tell it like it is!
Old 01-03-2009, 11:06 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Will the 91-94 Legacy Turbo tranny work in an SVX
1995 POLO LSI 76K MILES SOLD
Old 01-04-2009, 03:47 PM
I believe it will but most stay away from those as the turbo transmissions are more likely to be abused.
