Auto-X tires... and sizes
Hey guys, I am getting a set of RX-8 wheels that will be dedicated race wheels. I want to get a good r-comp on them looking to run 255's. Whats a good tire at a reasonable price and what sidewall ratio should I look for??
Thanks Tom |
Re: Auto-X tires... and sizes
I know a guy who can recommend a good tire aspect ratio, weight/grip ratio, low cost imbalance ratio, and even other ratios that no one else even knows about. He is local, lives with his mom in Salem, and also works at his mom's bar....
I think the new Toyo R888 is high on the list of favorites, now that they're phased out the RA-1. This isn't from experience, just what I hear from the local club, many of whom are very serious racers.
They will help your trap speed! And so that you don't lose horse power make sure that you only torque them to 45ft/lbs! And be sure to use tire shine ALL OVER on those to protect them from the UV rays. Just trying to help. HEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHEHE HEHEHEHEHEHEHEHEHEHEHEHEHE, SNORT! THIS might even things up a bit!
BTW, do you like donuts?
YT,
Aren't the RX-8 rims 18"? 255 is as wide as you're going to be able to fit without having to roll/cut the wheel wells. Hoosier A6s are great, as are Kumho 710s. If you're looking for a tire that will last longer, the VictoRacers are great (they're what I started out on, at Harry's suggestion). I've heard good things about the R888 as a track tire, but I honestly don't know anyone who's running them in autoX. -Bill
TOm |
My guess is that you are sticking with the 18" rims because there is potential in the future for a different set of front brakes, one that would require bigger wheels.
Tom a couple of questions:-
Is 255 the widest tyre you can fit on that rim? Has the car you are fitting them to got coil overs? Are you going to run wheel spacers? Have you used a tyre size caculator to see what fits under there such as this one http://www.1010tires.com/TireSizeCal...?action=submit. I run on my car 235/ 70R 16in and they took a lot of work to fit. You need the widest tyre you can fit under the guards. The problem areas are bolt on the rear arm pivot point which you can modify a bit to gain some room and use spacers. Also clearing the spring if you don't have coil overs. I don't expect you will get the large diameter I have so the rest of the issues I had won't be a problem. Tony
Tom did some checking my best guess is it will size 255 / 30 18in reason I say this as the outside diameter of this size tyre is only 20mm less then the standard. The width is about 20mm wider then what I run but due to the smaller diameter you might miss the nut at the back.
For my 2 bob's worth you should take one of you rims to a tyre dealer and get him to fit a worn out tyre of the size you are thinking then try it on the car. Tony
The Bridgestone RE01-R's on my car have been very good on the track. They release progressively rather than suddenly, which gives you a chance to catch it before you lose it. That quality might be more useful on a road course than Autocross, however.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Yea, the slow release of a street type tire is really not a good thing on an auto-x course... but I think they are great for track racing. I will be buying the tires over the course of the winter so I will have plenty of time to find the best tires
Tom |
YT,
Agreed that a 30 profile is probably the solution with 255. -Bill
