Old 07-29-2008, 10:46 AM
deuce deuce is offline
Door Lock Problems
Tried to unlock the driver side door with the key this morning & it wouldn't turn. It doesn't unlock from the inside either. Any suggestions?
Old 07-29-2008, 10:59 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Door Lock Problems
The door lock servo is causing the problem. First, remove power to the door locks either by pulling the fuse or by disconnecting the battery. Then try to lock/unlock it.
If that doesn't solve it, you'll have to pull the door skin off to get into the servo and replace it.
Old 07-30-2008, 10:27 AM
Removing power to the door lock did the trick. Guess its time to replace the servo. Thanks for the help.
Old 07-30-2008, 05:31 PM
Hocrest's Avatar
That's not always necessary. Sometimes it just sort of gets caught. Mine did it once years ago and hasn't given me a problem since.
Old 07-30-2008, 05:51 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
I had the same issue, and I just swapped fuses, even though the one in it didn't look blown. Tarded, I know.
Old 07-30-2008, 07:45 PM
My pass side one was frozen up when I bought the car. I just pulled it out and used the locks manually. Canadian SVXii never came with the remote security system anyway, so I'd still have to unlock my doors manually.
Old 08-01-2008, 04:43 PM
aust92pearl aust92pearl is offline
pull the door skin off the same happend to me the door lock actuator had come off the rail and jammed up against the rail in the lock position i heard a crunch sound sorta but nothing broke hope that helps
Old 08-03-2008, 11:00 AM
CorSVXette's Avatar
CorSVXette CorSVXette is offline
SVX- My daily driving Corvette
Send a message via AIM to CorSVXette
Classic SVX
While were on the subject of door lock problems, riddle me this Batman. When the alarm sets the locks sometimes go down and sometimes they don't. Sometimes one goes down while the other does not. Maybe needs some kind of lubrication somewhere It really is a scary thing when I come out in the morning to find out that the doors were unlocked all night
Paul
1969 Corvette
1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS!
1995 Corolla
2003 Highlander
