Where the SVX is rusting
I got a few places the SVX is rusting and I thought some of you would want to know about this. Please add to this list if you got more places.
1. Rear strut mount 2. Replaced hood and front fenders 3. Around the rear wheel well 4. Bottom of body from picking up with lifts 5. Oil pan The rear strut supports go if the salt and dirt has not been washed off. This dirt sits on top of the strut and is similar to powder. Just a light “touch” and it falls away. I replaced the hood and front fenders about 6 years ago. The hood is rusting inside the seams and the fenders are rusting inside the wheel wells. I think I would have done better with parts from a salvage yard that got painted and rust proofed at the factory. The plastic liner inside the rear wheel well holds dirt up on top of the liner over rear wheel well. This dirt sits against the body and holds moisture that eats into the metal body panel. Holes from and then moisture gets into the seam between the inner and outer panels. This starts the rust from inside out on the body. This showed up as bubbling rust at the back of the wheel well on my SVX. The body of the SVX where it gets damaged form picking it up with a lift will rust where the undercoating has been scraped. The oil pan is rusty on my SVX. Take care of that SVX! John
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
Alot of people have issues with rust forming under the claddings on the doors. seems water gets in there, and rusts the metal bracket that holds the bolts for the cladding, as well as in the holes in the door where the said bolts go.
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
My 92 black parts car had rust buble at left front corner of the sunroof.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker ![]() My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
Mines got a few bubbles around the rear driver's fender.
I also suspect the rear strut mounts are not doing well. Overall, for a 16 year old (Japanese) car in the northeast it's doing great. |
How is the rubber edging around the wheel well doing? That has metal inside it and when it gets wet the metal gets rusty inside the rubber. Then it looses it's spring and doesn't hold the surface as well. It sort of starts to come off and not lay as nice.
the only place i have rust is a tiny bit at 2 corners of the sunroof which is gone now and i found a hole under the pass.kick panel by the seat bolt, but i quickly fixed it and reundercoated it. I think it was cause by poor body work done form a previous wreck because i notice the rocker was replaced by seeing the putty crack in the door jam
Both of my doors have holes I can put a finger through at the top of the plastic cladding. My rear wheel arches are made of bondo by the previous owners patch job (good paint though), the corners of the fender arches are going, the fender stays (metal bar that holds the fender) are done, and the inner sunroof frame has a nasty spot.
I hate rust.
no rust whatsoever, little stonemarks on the hood and fender
parked outside and used all year round, now 230.000 km Rinus |
parked outside and used all year round, now 230.000 km 1992 Rinus |
Water lays there on my car, I would suspect that rust would ensue.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
