Relocating the Battery
I just bought a red top, and I have the ground wires... Any idea where it can be put? I dont have a rear seat, Has anyone else moved their battery? Is it ok to do?
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
While running the ground to the frame in the trunk does work (thanks Tom!), I'd recommend running a ground wire back up to the engine block at the same time you run the + line. A little more work, but I've found it's worth it.
-Bill
if you drive down to alewife for the meet on sunday you can see how I did mine.....
This will involve extra work, cost and bulk. If the battery is properly grounded to the steel shell and the engine likewise, it is highly unlikely that a wire, even of excessive dimensions, will provide a path of lower resistance. Is it worth it?
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
