WTB: huge list of stuff
My car is turning into a money pit. I priced all the stuff I need from the local Subaru parts place, and the whole list comes in at just under $2700.
Obviously I would like to save a little cash here and there if I could. The list: Fuel Tank* Sending unit Rear diff bearings (all 4)* Timing Belt Timing Belt Tensioner Timing Belt Covers (all 3 pieces) Water Pump Thermostat & seal Lower Rad Hose* Cam & Crank seals Some of this stuff I am just replacing because I will be "in there" anyway, and I don't know if it is bad or not. The major issues are marked with an asterisk. Thanks.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
There's usually a timing belt kit on Ebay from Prefered Components at a decent price, sometimes there's a water pump packaged with it.
PM'd you....
you would be suprised how much of that stuff advanced auto carries. Also when you say rear diff bearing, do you mean rear wheel bearing?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
No, I mean pinion and carrier bearings inside the rear differential.
wow, dead already? or is it for the stock car? if it is for the stocker, save yourself the trouble and just buy a newer low miles diff.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
This is for the modified car. It uses the stock diff housing and parts with a 3.90 ring gear from an older Legacy turbo, so presumably the bearings are original, with 107,000+ miles on them.
I would only replace the lower radiator hose with a new one. It isn't worth the amount you save to get a used one.
Tom |
PMed you, Tom.
