Old 12-16-2007, 05:41 PM
Wikedjuggalo's Avatar
Rebuilding
Computer Hell.....
O.k so great weekend I got a new radiator fan ordered :P but something else has to strike.
The computer I spend 1200 on to build myself no less then 3 months old craps out on me today. It kept crashing to blue screen of death. I am so mad. I tested the hard drive, the memory, and the video card. The only thing left is the motherboard crapped on me. Its a Foxconn and a nice one. I have to call them tomorrow.
The code I keep getting is 0x0000007e ( 0xC0000005 , 0x8052AEBE and cant remember the rest). Windows will not load just gives that error. If I cant figure this out this might happen.
/rant
Old 12-16-2007, 05:46 PM
Ouch, I feel your pain. The last computer I bought in store waited until the week after it's warranty expired, then ate it's motherboard.
I used it as an excuse to upgrade.
Old 12-16-2007, 05:47 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I would try flashing the Bios to a newer revision. the 7E bluescreen is very vague, as it can range from something as a video driver being corrupted, flaky BIOS or software corruption too.
My neighbor just had the 7e stop blue screen from a bad virus infection. It blue screened in safemode after reaching the desktop both in regular mode and safe mode. I ran a repair on his windows installation and it still the same. The only way we got it to work was after formatting it. That was the only way to get it to run stable again.
Does your machine run in safemode? If it does i'd try updating all of your hardware drivers, including videocard, motherboard chipset, soundcard, network card etc...
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-16-2007, 05:49 PM
Rebuilding
No it does not at soon as it goes to load Windows it goes to blue screen. I can not get into the Windows >.<. I am going to have to call Foxconn I guess because I spent all day, 12+ hours trouble shooting everything. Memory Test, Hard drive wipe and reinstall x3 of windows, and changing Video cards. I will try updating the BIOS if available.
Old 12-16-2007, 06:02 PM
crazyhorse's Avatar
242,000 mi on oem trans
Take the machine down to it's bare essentials....the drive, mobo, and video. In the BIOS disable everything NOT related to those. NOW try to boot the machine. If it boots, start enabling things one at a time, until it fails to boot. NOW you know where the problem lies. Disable it, update the driver, then enable it again.
"42"
Current Stable By Age:
Old 12-16-2007, 06:07 PM
Rebuilding
I did that Nothing enabled it to run. Why I suspect the MoBO is failing or flashing it might work but idk.
Old 12-16-2007, 06:28 PM
Tim's Avatar
Tim Tim is offline
Sounds like it could be a bad mobo. The very last thing I would try is a spare power supply, since PC's can act very odd when being fed bad power.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-16-2007, 06:38 PM
crazyhorse's Avatar
+1
Mine eats at least 1 PSU a year.
"42"
Old 12-16-2007, 06:52 PM
SomethingElse's Avatar
word words wording
+1
striking you may want to invest in a high quality UPS.
Eric
Old 12-16-2007, 07:00 PM
crazyhorse's Avatar
I have a good UPS
And I only use Antec PSU's
Nobody can tell me why the 5v dies.
"42"
Old 12-16-2007, 07:04 PM
Turbone Turbone is offline
Banned
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
Do you have a install disc for the HD? You should be able to use it to check the partitions on the HD. I would look into that and a reflash of the BIOS.
If all else fails use the method in your pic above ^^^
Tim's Avatar
Tim Tim is offline
How old are the fans in your system? How humid is your house too? That is quite odd that you go through so many power supplies.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-16-2007, 07:19 PM
crazyhorse's Avatar
I know it's odd, I usually keep a spare though. I also keep it spotless inside. I've just learned to live with it. The fans are all 12v, and it's been doing it since the system was new. Every component has changed since then, except the mobo. I built it 4 years ago.
"42"
Old 12-16-2007, 07:35 PM
Speedklix's Avatar
Locker Link Solution
I have a good UPS
yeah me too... it seams to be the monitor that kills it.
every now and then it takes the gfx card too.... I just can't bring myself to toss it though i've got 2-2.5 years on that system since snaping one of those magnetic suppressor deals on the cord. I had a spare from a printer and just gave it a shot.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 12-16-2007, 07:41 PM
Speedklix's Avatar
if you disconnect the HD do you get the can't find an OS sort of messege?
if you can, then reconnect, setup the board to boot from CD and do a repair install for your os. i can't remember if this overwrites your personal documents or not, but I don't believe it does.
-Mike
[SIGPIC][/SIGPIC]
