#466
Overheard in YT's classroom.
"Yea, he's just an old grouch!"
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link |
#467
Boost comming on quick is the wonderful thing about superchargers. I bet what is happening is the cams are allowing the supercharger to work much more efficiently, causing your boost to go up throughout the rev curve. I think you may need to do some more tuning with this motor. I'm glad you are bringing this up, as this will be an issue for all of us to deal with.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#468
His motor isn't even built yet though and he won't be running a stage III set up......
#469
#470
I got to thinking last night, I don't think the cams will cause more boost. In fact they should reduce the boost since they will "consume" air faster. Hard to tell though. Wasn't the tune done on a 9 lb. pully? If this was the case, this might be the problem with your tune.
#471
i was going to say that but I figured you would realize what you were saying. I am buying a rom reader/writer/eraser in the near future and I have a flashable chip for it. Using that with my g-tech I will try my best to get a better tune on the ol girl
Tom |
#472
How much does one of those cost?
#473
probably gonna cost close to $1k for the hardware
![]() Tom |
#474
That's a good price.
#475
Got my heads back from the machine shop. They look nice with the pretty new valves. Got the block back, but had to return it to have some grooves cut in the semi decking to allow some better coolant flow, since the inserts extend into the water passages. There is some room between the gasket and the bottom, but I want more room for sufficient flow. Also he needs to cut rings on the last three of my pistons. Hopefully he will finish by the end of the week so I can start to slowly assemble everything. I also received the cometic head gaskets and other subaru motor parts. I'll take pics as I progress through the assembly.
#476
Re: Engine Build Progress and Questions
THIS NEVER GETS OLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#477
and you dig up a thread from 2007 to abuse me with?
![]() ![]() Bill
#478
I have been pouring over engine build threads all day long.
At least THIS^ part was fun! ![]()
#479
Ive been doing some research as well. Where the heck can I get parts from anymore?? I need pistons,cams,rods..possibly valves...AHHH!
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click |
#480
Reviving a thread from the dead! I need to get a hold of LAN. Building an EG33 for boost
![]() LAN if you see this I sent you an email on 7/21/16. I need to know if you still have some engine goodies on hand. -Sam
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
