Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
You have to check with some suby dealers and see how long their master tech has been working there and if there is an SVX specialist....but my first choice would be to get it to someone such as Tom where you will know it will be done correctly and alot cheaper.
Why don't we press bearings in? I had bearings pressed in on my Legacy and they were still silent after 30k miles.
I always thought a press was the best way to go on these matters. And there's no way I'm going to the dealer and giving them $500 to do one wheel bearing. Eff that. I can go to my mechanic and have them ALL done for $500.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Thanks, for the advice! I need Tom to get in touch with me and see what he can do for me. I have an awesome mechanic, I havent even asked about it yet. (remember he did all my Drilled/slotted rotors, SS lines and pads for 75$!) Cant beat that! But if ya'll are saying he can press them in...Manarius...I think Troy can do them and hes only 2 miles away. <p>Yeah its driveable, good thing cause I hate my explorer, Once you go SVX ya never go back! LOL I have been giving it a rest about 3 days a week because I know its hurt! <p>Thanks guys for the GOOD info, I like to come here for the info I know I can always get!
![]() If I am the Tom that you are looking for my secret phone #is 301-707-3437. We have been totally busy with the four day Pumpkin Carve event ![]() ![]() ![]() Tom
I am pondering the idea of replacing my wheel bearings and have always thought that the ability to regrease the bearing while still assembled would help the longevity of our bearings. Anyone here ever have one out and look at it themselves?? If there was a face inside of the bearing seals that did not have pressure being applied to it, I would be willing to drill and tap a hole for a grease fitting in there. I'd give it a try if it was even possible! Ok guys, don't be too harsh if it's impossible!
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
This is not a journal bearing with a housing you can put a grease fitting on...I'm not sure where you would think to put one based on your description.
The problem are the seals letting in debris or grease out...You are not fixing the problem if you are adding grease because the seal itself is still the issue. The bearings should come factory lubricated and you really shouldn't have to do anything with them....although some members repack them with higher quality grease. |
I should have mentioned that mine is FWD, bearings should be housed a little differently. Also, I must disagree, being able to replace the old grease with new grease as often as needed would lubricate the bearing in a much better way. This is especially true if the seals are leaking..... think about it. Bad seals allow debris and moisture in, force it out with new grease every oil change, hmmm.... might do something!
The bearings are set up exactly the same on the rear wheels in AWD vs FWD, there is just a "stub" axle in the rear on the FWD models. There isn't anywhere to drill a hole to get access to the inside of the bearing. It might help, unfortunatly, it is impossible. You could take out the stub axle and the seal, and then the inboard inner race would be visible and you could try and pack some grease in there, so it is theoretically possible to re grease the bearings, but I don't know if it would help or not, you may do more damage than good. It usually seems to be the outboard bearing set that wears anyway.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) Last edited by NiftySVX; 10-31-2007 at 06:39 PM. |
thanks for the help, atleast I have an idea of what I'm going to see when I get to it. I haven't seen a description on the FWD until now! I'm sure yall are right on the grease fitting, I'll look but everyone on here is pretty knowledgeable, so, I'm not hoping for a breakthrough.
