Old 08-08-2007, 07:03 PM
Dengue's Avatar
Dengue Dengue is offline
My kitten can woop your kitten
Send a message via AIM to Dengue Send a message via Yahoo to Dengue
patching an exhaust leak
I have an exhaust leak on one of my pre-cats, and my inspection is about to be due. I know there is such an animal as an exhaust patch kit, but I was wondering if JBWeld would be able to survive the heat of the exhaust, or some similar product.
any thoughts?
Skip
'95 SVX L - Laguna blue 126,000+ miles
'89 XT - some sort of sun bleached blue
'00 Hyundai Sonata- charcoal gray (hers)
Old 08-08-2007, 07:18 PM
any thoughts?
Skip
The leak is (almost) always at the flange just before the two into one, main cat.
You have to cut out the perforated metal pipes, and replace them.
Since the pipes are only 1.61 inches in diameter there, you probably have to take it to a welding/exhaust shop that you trust, and have them fix it for you.
Hopefully they can fix the rusted tube, or more likely just weld in , say a 1,3/4" tube, about 4" long and just replace the flex coupler.
This is assuming you want to do this cheaply.
Old 08-08-2007, 07:55 PM
processengr's Avatar
Hi Tom,
Would flex coupler = exhaust gasket on subaruparts.com?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-08-2007, 10:37 PM
It's Just Eric's Avatar
Missing in action
Once the exhaust is rusted through, it's pretty tough to weld It doesnt ground well, and since it's rusted thin, you tend to burn through alot
give welding it a try, but odds are you're probly better off having someplace make you new front pipes. You can order resonators in place of the cats, and it ends up being fairly inexpensve
R.I.P Cool Signature.
Old 08-09-2007, 07:13 AM
Wouldn't it be nice if we could do a group buy, maybe from SVXFILEs,of the E3 exhaust pipes..(hint,hint...)
Cheers! Gordon
2018 Tesla M3 30k
Old 08-09-2007, 07:33 AM
JaySVX's Avatar
JaySVX JaySVX is offline
I've patched small holes and leaks in exhaust with JB Weld. My ex-wife backed into a curbe and severed the pipe between the cat and the muffler. I took a 2" pipe, cut it down the middle, put it over her pipe to hold it together, used 2 hose clamps to hold it in place, jb weld all over it, let it dry, started it, found tiny holes i had missed, patched them, and it was good as new(unless you actually looked at it...)
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 08-09-2007, 11:11 AM
svx_commuter's Avatar
I just used some cold weld glue stuff that is good to 2400F. bought it at advanced auto. A friend has it on his car for over six months now and it is holding. The pipe gets cleaned off and then the stuff put on. Then let it sit for 4 hours. It gets rock hard. Then start it up and the heat cures it. The pipe on my SVX is leaking the same place yours is leaking, bottom of the pipe between the heat shield bracket and flange. I'll get the name posted when I get home.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 08-09-2007, 11:32 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Mine is doing the exact same thing on the driver's side. Between the cat and the flange. Mine has actually separated and I have to take off the heat shield to see what's rotted through. I'd like to replace the pipe from the cat to the flange, but without a solid one to use as a template, I'm not sure how a pipe bender would get the curve correct.
Eventually I'll take one off the other car and take them both in to have a pipe bent up. Maybe I'll price getting a dozen pipes and sell them to others at cost. I wouldn't hold your breath for them, though. I tend to be a little slow at getting things done.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 08-09-2007, 05:23 PM
If you get some cat to flange pipes, count me in! Will they be mandrel bent or crush?
Cheers! Gordon
2018 Tesla M3 30k
Old 08-09-2007, 05:54 PM
This stuff is called "ThermoSteel" CarGo Part# 18003
Made by Blue Magic, Inc Conroe Texas
The stuff I left out since Saturday is hard as a rock
They claim it can be machined or drilled or sanded just like metal
Sand balsting is recommended before application
It claims to have no hazarderous chemicals no VOC's
Take care,
John
Old 08-09-2007, 06:54 PM
Dengue's Avatar
actually, my leak is a split on the seam on the pre-cat, I put jbweld on the seam, and I will see how it does tomorrow I guess.
Skip
Old 08-10-2007, 07:52 AM
mohrds's Avatar
Most likely crush unless I go search out another shop to work with.
I'll post the specs before I have any extras made.
1994 LSi (4/93)
2000 Ford Excursion
Old 08-10-2007, 08:57 AM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Why not just cut the pre-cats and flanges and replace with straight pipes.
Old 08-10-2007, 09:55 AM
mohrds's Avatar
Some of us have to suffer through emission testing and inspection. Missing emission parts equals big $$ fines. I think the minimum fine is $500 for removal of emission parts.
1994 LSi (4/93)
2000 Ford Excursion
Old 08-12-2007, 05:45 PM
Anyone know of a source for the precat to main cat flanges, or 1 5/8 OD to 2"ID adapters to splice in a Magnaflow 007? I Google searched, tried JEG's, no luck...
Mine has the condition Tom has described, leaky pipes just before the flanges into main cat. Got a Magnaflow 007 for $65 delived! form Performance Peddlers.
Cheers! Gordon
2018 Tesla M3 30k
