Old 05-17-2007, 06:54 PM
How to on Fuel Filter Replacement
The only info in the how to documents concerning fuel filter replacement is to disconnect the fuse under the rear passenger seat. Is the replacement of the fuel filter that simple? just disconnect and insert new?
Old 05-17-2007, 07:29 PM
billb billb is offline
It's pretty simple. Just pull out the rear seat and disconnect the fuel pump wiring connector. Let the car run until it stops from lack of fuel pressure. Then go under the hood and change the filter. You'll still get some gas running out of the fuel lines, but it won't be under pressure. Some people don't realize that you have to relieve the fuel pressure so gas sprays all over when they disconnect the fuel lines from the filter.
Bill
Bill
94 SVX LE 130,000mi
Old 05-17-2007, 07:46 PM
bill, thanks for the info....just so i understand correctly...i have to go underneath the car to replace the fuel filter? Can't i just remove the silver canister (driver's side) from there? Also, will i have a problem turning the engine over after i install the new filter and reconnect the fuel filter plug?
Old 05-17-2007, 07:49 PM
SomethingElse's Avatar
word words wording
I just let gas drip its not that bad. but I guess it creates a fire hazard.
its under the hood next to the drivers side strut tower. no underneath required
Cycle the key 2-3 times and let it sit for a couple seconds each time to rebuild fuel pressure
ps.. note the position of the filter and the hoses connected to it.
Eric
immortal_suby's Avatar
Thread Killah
Nothing under the car. You are correct, just change the filter in the engine compartment out with the new filter. Plug the fuel pump back in start her up. Might crank for a little while on the first start but after that you are fine.
Also - get a clear container and dump in the remaining fuel from the old filter. You might be surprised at how dirty it is.
Locker Link
2015 BRZ Limited 6MT
Old 05-17-2007, 08:00 PM
wow such prompt responses! seems pretty straightforward, let everyone know how it turns out, thanks again!
Old 05-17-2007, 09:09 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You might have a little struggle taking the hoses off. Some have cut them off and replaced them. You can carefully pry open the end of the hose with a screwdriver and spray some lubricant inside for easier removal.
Old 05-20-2007, 06:53 PM
There is some information in the How-To Documents on this. Check here for location of the pump.
Old 08-04-2012, 12:09 PM
theflystyle's Avatar
Re: How to on Fuel Filter Replacement
just did the change using this hose plier tool. I didnt do anything with the fuel pump, fuses, etc. there isnt that much gas that comes out but just have a little cup ready
1994 SVX LSi
2008 Legacy 3.0R
Old 08-04-2012, 02:57 PM
Darren's Avatar
Darren Darren is offline
If any hoses are tight or brittle I always pour boiling water over them for a few seconds to soften them up, it usually does the trick without forcing, cutting or breaking anything.
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 08-04-2012, 03:21 PM
That's an interesting trick... Thanks, I'll keep it in mind.
