Tranny swap
I am new to this idea, but my 92 LSL just lost second gear. I am at a crossroads I can either repair, replace, or swap. is there an affordable, but performance friendly swap that can be done? The way I see it if I rebuild , I take chances on having the tranny take a crap on me again. If I replace with the same, I inherit new problems. If I swap to manual, I want a good performance tranny (6 speed). Which is my best option?
The cheapest and easiest tranny upgrade is a 4.44 Outback Tranny and rear diff.
They'll handle the power better, and get the power to the ground better. And is almost a bolt in deal (just have to swap the rear diff ring and pinion)
swap
4.44 outback tranny & Diff huh? What years should I look for?
better yet will a 2002 WRX 5 speed work? Just kidding but there is one on ebay.
Actually the 2002 WRX 5-speed will bolt up to the EG33 in the SVX, but does required some custom fabrication to make it work (see my write up in my Sig) As for the Outback auto 4.44 Tranny Any Legacy Outback or Legacy GT from 1996-1998 (but some of the 98's won't work, you can tell if they have a spin on filter on the side of the tranny case, it won't work)
I would familiarize yourself with the search engine theres tons of info on 4.44.
96-early 98 will work. the 5 speed will work too but that needs more fabrication.
STi 6 speed is "the best" option that your talking about...
...or a 5 speed with the r/a gearset. The close ratio 6 speed is a little overkill for the eg33's torque curve (Though that is mostly a matter of opinion)
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
Just out of curiousity, what's the latest year 5 or 6MT that can be swapped? The only reason I ask is there's a brand new 2006 STi 6MT (With rear diff, driveshaft, axles, starter, x-member) on Ebay right now currently at $455. Is that do-able?
http://cgi.ebay.com/ebaymotors/Brand...QQcmdZViewItem Edit: It's not at $455 anymore. Big surprise there.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 02-01-2007 at 11:12 PM. |
other than ebay, does anyone know where to get the Tranny and diff? I want to get a rebuilt or used set.
Check your local junk yards.
www.car-part.com you can do a search there and narrow it down by milage or price. ..etc
Will the Impreza 2.5 RS 98-03 tranny fit? I am having a hard time finding a suitable tranny. The 2.5RS has a 4EAT with a 4.44 LSD.any $eat should fit right?
NO
It has to be a pre 98 4EAT, mid year in 98 they changed the 4EAT, and the newer ones won't work with the SVX TCU (Transmission Control Unit) you can tell a new version by the external "screw on" filter (looks like an oil filter) on the drivers side of the tranny.....if it has this filter, you CAN NOT use it.... so it needs to come out of a "Legacy GT", or "Legacy Outback" 95-98 to get a 4EAT with 4.44's that will work with the SVX
thanks, I am new to this, thank you for your patience.
