Old 09-03-2006, 03:00 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Angry Driver's door doesn't want to lock
Okay, this one is starting to be a bit of a pain, so I'm looking for some help from anyone who's had this happen to them. I checked old threads before posting, so I've already pulled the 15A door lock fuse under the dash (middle column, second from top) and pulled off the door panel so I can see what's happening with the latch. I've also disconnected both of the connectors that plug into the lock solenoid, and the lock still wont "lock" when I try to push the lock button down. I would think - from a safety standpoint - that the lock should lock/unlock with no power to it. Am I wrong? If I'm right, does this mean the solenoid has just crapped out in the unlocked position and I need to replace it?
Thanks in advance for everyones' help.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-04-2006, 02:23 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
The lock button is purely mechanical. It should work even when there is no power to the door locks. You need to remove the lock and have a look at it, or just get one from a breaker.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-04-2006, 10:20 AM
SVXRide's Avatar
Thanks. I thought that was probably the case
-Bill
