Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 06-10-2006, 03:08 PM
Amazonparrot's Avatar
Amazonparrot Amazonparrot is offline
Now with Colder Air!
Send a message via AIM to Amazonparrot Send a message via MSN to Amazonparrot
Is my offset too low to drop the car??
I am trying to figure out if my wheels will allow me to use dayles drop kit to lower the car, or whether the low offset of the wheels will cause rubbing when lowered.
The Scenario:
18" x 8" Enkei CP01's 38mm Offset
225/40/R18 Pirelli Pzero Nero Tires
The springs:
Motorsport SVX's 1.25" Front / .75" Back Drop Springs
http://svx-motorsport-accessories.st...opsprings.html
Does anyone have comment on whether these will fit together or not?
Also, does anyone have pictures or info on the K&B drop springs?
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD*
2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp).
Charlottesville, VA Represent! (voted #1 place in America to live!)
http://www.subaru-svx.net/photos/user.php?Amazonparrot
Old 06-10-2006, 03:21 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
if it doent rub now then it shouldnt rub after the install talk to dayle directly he would know best
- John
Old 06-10-2006, 04:30 PM
It will probably rub in the back. If not during normal driving, everytime you hit a bump.
Old 06-11-2006, 02:42 AM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Send a message via AIM to SVX10 Send a message via Yahoo to SVX10
I'd guess those wheels would rub. I've got 42mm offset 8" wide wheels, and I certainly don't have more than 1-2mm of clearance. The 38mm offset would be really pushing it as it would make that gap even smaller. You can always get new wheels
Time for my very own long list of mods:
92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler
I don't care if Subaru says it's STI...it will always be STi to me
Old 06-11-2006, 05:55 AM
Yes, but have you seen his wheels?
"Its the car. Chicks dig the car!'
Old 06-11-2006, 10:07 AM
Tom DOES have a point...the chicks do dig the car:P Is there any definitive way of finding out whether they will rub...i really want that front gap gone....and what about rolling the fender lining in...not that I really know what that entails
Old 06-11-2006, 06:32 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You'll probably have to add camber bolts to the rear and then run at least a degree of negative camber front and back to keep the tires from rubbing -- educated guess.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-12-2006, 12:39 PM
Earthworm's Avatar
Meow!
You could always try adding 300lbs in your trunk (or 2 large passengers in the back) to see if you can get the tires to rub while driving.
Old 06-12-2006, 01:21 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
Bring them up to me. I got the springs on my car. I can also test the traction of your tires.
Old 06-12-2006, 06:17 PM
SVX10's Avatar
If you don't have time to do the other stuff, I'll measure my current clearance and give you some calculations that should give a good indication as to rubbing with drop springs.
If you're worried about gettin the ladies, you could buy my old Konig Flights. Check May on the SVX calendar for undeniable visual proof of sexyness Juuust kidding...one is cracked. You can still buy them though...smokin' deal if you know where u can get them fixed!!
Old 06-12-2006, 07:56 PM
Suby Fan's Avatar
there are a bunch of places that do rim repair around here (thank you MN winters) how much? balencing them once they're repaired is a b1tch though
- John
Old 06-19-2006, 01:18 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
they will probably rub on the rear if you have more then
one passenger.
My Murano wheels are 7" wide with a +38mm offset and that
car has my springs in it, on hard bumps on the freeway it will
slightly rub, you can hear it, although theres no damage.
With 8" wide wheels like you are asking, it will be a little closer.
Mine doesnt bother me near enough to worry about it but I rarely
ever have more then one passenger in my car, even with a 2.5
yr old in the baby seat in the back its not a problem.
The rear lip is pretty wide, you can carefully fold it upwards to
add about 1/4" of clearance, which helps alot.
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
