Old 08-20-2005, 09:43 AM
terror terror is offline
Won't start
Car cranks but does not fire. Full of gas. :-)
Flashing 'Check Engine' light indicates no codes.
Is this a bad ECU? How do I check?
Daughter stranded.
Thanks
'95 SVX
'65 Sunbeam Tiger
'85 Alf Romeo GTV6
Recommendations for a '75?
Old 08-20-2005, 04:45 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Question
fuel pump? fuel filter? ignition control module? timing belt? did it die while running or just not start the next morning?
Old 08-20-2005, 05:34 PM
Daughter stranded.
Thanks
Check your fuses first under the hood, especially the fusable link, and the ones under the dash on the drivers side and report back to us.
Old 08-21-2005, 06:50 PM
Fuses good
All fuses under dash and under hood checked good. Smells of gas when cranking, so I'm thinking fuel pump is OK.
If the ECU was bad, would I get the flashing 'check engine' light?
The car drove fine to parking lot at work, did not start after work. I went to check it, it did not start. When ignition turned on, all idiot lights stayed lit.
I checked codes at pin 2 behind kick plate, constant flashing on indicator. Then car started. I removed blue wire and car started 4 more times and ran fine. When my daughter went to pick it up, it would not start and has not started again since.
Thanks guys.
Terry
'95 SVX
'65 Sunbeam Tiger
'85 Alf Romeo GTV6
Old 08-21-2005, 07:48 PM
SvXSubaru92's Avatar
SvXSubaru92 SvXSubaru92 is offline
1992 Subaru SvX
Send a message via AIM to SvXSubaru92
I have a similar problem, after swithching 2 injectors with one another, the car won't start, and it smelles like fuel, almost started sometimes, now won't even try to start. Is there a way to check the fuel filter? Is it ok to bypass it for trying? Sorry for jumping into the thread.
Old 09-26-2005, 07:48 AM
It was the fuel pump.
I first tried the fuel pump relay, because it is sooo much cheaper, but it turned out being the fuel pump.. I am disappointed that there is no code to indicate that.
TG
'95 SVX
'65 Sunbeam Tiger
'85 Alf Romeo GTV6
