Old 07-05-2005, 01:43 PM
billb billb is offline
How to Tighten AC belt?
Does anyone have a good technique for tightening the ac belt? It's tough to push the tension pulley over and lock it down. I hate to put a pry bar on it.
Old 07-05-2005, 02:10 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
There are two nuts/bolts to loosen/tighten one at the pivot and one at the end of the arm (I think both are 12mm). Loosen both and use a wrench (14mm??) on the wrench flats behind the nut/bolt at the pivot, while holding that one tighten the other end and then tighten the pivot.
Old 07-05-2005, 06:25 PM
Earthworm's Avatar
Meow!
I believe it's a 17mm. I tighten the nut that pivots first followed by the center nut.
Old 07-06-2005, 04:01 AM
Thanks for the tips. I'm waiting for a new pulley and I don't want to mess it up when I do the tightening.
Old 07-06-2005, 07:38 AM
I hope this helps.
Old 07-06-2005, 07:54 AM
Hocrest's Avatar
Originally Posted by svxfiles
I hope this helps.
Yeah it sort of helps, but I don't have any large pieces of wood in my engine bay???? Am I missing something??
And as the picture shows, it is definately a 17mm used to put tension on it not a 14 like I guessed.
Old 07-06-2005, 08:30 AM
Must,,, resist,,, temptation ,,, to ,,, make ,,, wood ,,, joke! ,,,
Can't,,, hold ,,, out ,,, much ,,, longer ,,, !
Old 07-06-2005, 11:44 AM
Gee, mine looks just like that!
