brakes
Loseing brake flood and cant find where. If i push hard on the peddle at a stop it slowly goes to the floor. Does that mean the mastercylinder is going bad?
I've never seen a Subaru master cylinder, go bad, but if you remove the M/S, and reach into the brake booster and you get brake fluid on your finger/probe, then yes, it's leaking into the booster.
No puddles anywhere?
If you lose the pedal at a stop with the brake reservoir full of fluid, then yes, the master cylinder is probably worn to the point of letting fluid seep past the piston.
dcb |
thank u for the info. earthworm i have peddle when stopping just not when im sitting at a red light it will slowly go to the floor if i put presure onit
