-   Technical Q & A (https://www.subaru-svx.net/forum/forumdisplay.php?f=5)
-   -   brakes (https://www.subaru-svx.net/forum/showthread.php?t=21007)
92black svx 08-30-2004 04:52 PM
brakes
Loseing brake flood and cant find where. If i push hard on the peddle at a stop it slowly goes to the floor. Does that mean the mastercylinder is going bad?
svxfiles 08-30-2004 05:13 PM
I've never seen a Subaru master cylinder, go bad, but if you remove the M/S, and reach into the brake booster and you get brake fluid on your finger/probe, then yes, it's leaking into the booster.
Earthworm 09-01-2004 11:41 AM
No puddles anywhere?
dcarrb 09-01-2004 11:58 AM
If you lose the pedal at a stop with the brake reservoir full of fluid, then yes, the master cylinder is probably worn to the point of letting fluid seep past the piston.
dcb
92black svx 09-01-2004 03:31 PM
thank u for the info. earthworm i have peddle when stopping just not when im sitting at a red light it will slowly go to the floor if i put presure onit
SubaSteevo 09-01-2004 04:49 PM
I've got a master cylinder you can have for $25 if you need it, located about a half hour from Reading. PM me if you want it.
