http://www.subaru-svx.net/forum/show...5&pagenumber=1
There was another thread I was involved in that sparked a 'heated' debate. Bottom line is that tire pressure affects rolling diameter. - Rob |
Rob,
Just a measured piece of info to add to this discussion - when I was running in the MB autocross this Sunday I started with 39 psi in the back tires and 44 in the front to minimize the chance of the sidewalls rolling. After 4 runs the front tires had heated up to 49.5 psi while the back tires were still at 39. I used a digital tire gage for all measurements. It would have been interesting to have measured the O.D. of the tires... -Bill p.s. Harry (newsvx) and Mike (Rufus) also drove in the same autocross. Both of them did great -- I continue to learn from watching and listening to both of them.
You know, Bill, I'll be entering my first autocross in less than two weeks. I can't friggin' wait!
Re: Understeer reduction via tire size change
What's that??
Andy ------------------------------------------------------------------------------------ If I would be a young man again and had to decide how to make my living, I would not try to become a scientist or scholar or teacher. I would rather choose to be a plumber or a peddler in the hope to find that modest degree of independence still available under present circumstances. -- Albert Einstein, The Reporter, November 18 1954 |
-Would it be possible to use bicycle-computers (speedos) to measure each wheel (only small magnetos attached to the rim)?
Enjoy! Harry (newsvx) got me hooked on it. It will chew on your tires, so make sure they're in good shape. Actually had the car semi-drifting around the 270 cones - definitely a rush. Now, if I can only get my brain to listen to Harry's advice that "slower is faster".... -Bill
Of course, if you take any turns, you're going to see different numbers between those readings, anyway. I still think that the simplest way to test how tire pressure affects rolling diameter is to measure the distance between the center of the hub and the ground at different tire pressures. As much as I'd like to attach some sort of laser-rangefinder to the center of my SVX's wheels and see if the number changed at different pressures, I lack such an instrument. So I'll be using something low-tech. Like a stick. This is unquestionably less precise, but without a doubt cheaper.
-I had all 4 corners in mind .. and a loooong straight....
Then you can set different pressures and measure in "your" way, after that drive 1 mile or so (straight) and check the "counters" on the displays! |
rolling diameters
mbtoloczko [or anyone else who'd like to chime in..ta]
I read with interest your tyre experiment, in my case with my rim/tyre combination 265/35x9x18 rear and 235/40x8x18 front, according to tyre calc programs my front tyre has a larger diameter by 0.3inches to the rear tyre, but with weight over the front...which way will the air pressure gap likely go wider front to back or lesser. I will do the experiment after my car comes off the hoist, but if I can estimate the air pressure gaps to start it will give me something to work with..[yours with same tyre/rim f to b was a 7 psi difference..but with my front tyre being slightly 'longer' but with the weight of the engine over it ...do you see the psi gap even wider or narrower..??] Also how do you compensate for heat load.. perhaps getting it right for when the tyres are cold wont this change when say the front tyres have heat in them more than the rears.. Thanks dave
Dave Down Under Last edited by grnSVX96; 07-25-2004 at 05:26 PM. |
When I do the tire diameter calculations, I get that the dia of the rear is 0.1" less than the dia of the front. Since the tire diameters are a bit different, keep an eye on the difference in revolutions as you move the car forward. You might want to check every 1/4 or 1/8 of a mile.
#28
I wonder if it is possible to "tap" into the ABS signal sensors, maybe in the ABS control box, and build a simple frequency counter to monitor all 4 wheels
Maybe I'll check into that l8er /Sonny
Internal name: "SuperSonic" -92 ebony black with 170k KM *** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. *** |
#29
