Understeer reduction via tire size change
Has anyone tried mounting 245/45's on the front only with 225/50's stock on the rear as an attempt to reduce understeer on their SVX ? The 2 sizes are dimensionally the same except for tread width and Paisan et. al. confirm 245's fit w/o rub.
BTW, I put Prothane swaybar bushings (3/4"-17mm) on the rear on mine and have noticed definitely less push in the corners and faster turn in...at limit in wet conditions a bit more ready to throw the tail around. Nice cheap mod...you need to use their metal clamps with new bolt/nuts since the OEM bushing clamp is too loose. Craig |
Old thread revival begins!
stock 225/50's are 24.86" tall 245/45's are 24.68" tall difference = 0.18" or 0.7% That would definately reduce understeer however I would not want to drive like that all the time. It should be safe for a few auto-x runs but I would switch back to 4 equal tires immediately after. for reference 205/55's are 24.88" tall and would be safer to run with stock size. There's probably safer (to the drivetrain) ways to reduce understeer than different size tires on AWD vehicles.
Why not adjust/play with your tire pressures?
You'd be amazed what tire pressure changes alone can do for the way your car will handle. You can tune in over/understeer with tire pressures & a different alignment without upgrading a single thing... assuming you have tires with some kind of grip. |
I personally don't condone adjusting the tire pressure. You're just too likely to affect the rolling diameter and wear the transfer clutch assembly far more quickly.
I could run 20 Psi front and 40 psi rear and the diameter of my tires wouldn't be that much different at all. I'm talking about minor adjustments as well. From the factory Recommended tire pressures front to rear are different by 2 Psi IIRC. You really should learn a bit more about tires & tire pressure and how they affect handling before you say that it's 'drastically changing the tire diameter' Who are you kidding? |
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
Ok... so 33 front 29 rear is even more drastic, does that worry you?
If your sidewall aren't stiff, you need some new tires... what are you on... 1950's radials? So how did your tire pressure testing this weekend go? What kind of tires are you on? How often do you check your tires? What do you usually run them at? May I recommend this site to you for learning 'stuff'? http://www.howstuffworks.com They cover tires, tire pressures, pretty much anything you might need to know. Back to the original person having understeer issues... What tire pressure are you running? What tires do you have on your car (size, brand, speed rating)? Any other modifications that would affect handling? How good are you struts (if stock & high mileage)? * I bet I can give you some different tire pressure settings to try that will help. Thanks - Jon |
I've been to 'howstuffworks' many, many times. I don't think that tire pressure, as it relates to rolling diameter, has been covered on the site. As for Subaru's recommended tire pressure, I don't understand what you mean by 'does that worry' me. No, it doesn't worry me - I simply inflate my tires to those pressures. And, to answer your question, I check the pressure regularly and also rotate the tires every time I do an oil change. I was not able to get to the tire experiment this weekend. I was disappointed, because now I'm really curious to see the results.
The only reason subaru has more air preasure in the front than the rear is because the extra weight afects the rolling diameter. If you had 20PSIin the front and 40inthe rear there would be a measurable difrence probley more then there spose to be on the AWD. side walls flex a decent amount, or else there wouldbe no change to the handling by air preasure if they dident.
Hi folks, sorry if I intrude....
But... Tire pressure HAS effect on the rolling diameter...., maybe not much, but it has effect! I have owned as many as 6 Subarus with "diff-lock" systems, on those I usually "tuned" the rolling diameter with approx. 0,2bars more pressure in front to reduce the "diff-disengage" noise. (it builds up force when rolling diameter is not equal). When tyres are matched equally in this way, there is a totally noise-free disengage of the diff-lock. The effect of different rolling diameter is that there is a heat build-up in the clutch (plates,visco, whatever) because of the slipperage. (but not on "locked" systems) This heat can be more or less depending on the system used, and the amount of slipperage, but could cause the clutch to fail if enough heat builds up. To you who are tuning and tweaking your cars for over/under steer, check out the attached html file. |
-Sorry, here's the file....
Save and rename it to chassie.htm and doubleclick it.... |
I made an PDF of it....
The tires' rolling diameters (and the difference between them) effect on the transaxle is exactly why I'm concerned about how tire pressure affects rolling diameter. Your conclusion is what I have believed - that tire pressure doesn't affect rolling diameter much - but it does affect it. To what extent different tire pressures affect the rolling diameter I hope to find out. This additional heat caused by more slippage in the transfer clutch is of concern to me because, as we all know, this transmission is particularly sensitive to heat.
