Old 09-08-2003, 10:20 AM
jeradsvx jeradsvx is offline
Send a message via AIM to jeradsvx
4 wheel alignment
I was just wondering how much i should expect to pay for a 4 wheel alignment. I just put my car back on the road and it needs an alignment. It is pulling to the right. Plus when i am going 40 or so the wheel shakes a little so i hope an alignment will clear it up.
thanks
jerad
Old 09-08-2003, 10:43 AM
svxstl
I just paid $69.99 for one at Midas.
--Dan
Old 09-08-2003, 11:44 AM
AFBeefcake's Avatar
AFBeefcake AFBeefcake is offline
Subaru Swapper
Send a message via AIM to AFBeefcake
I paid $60.00 at townfare tire.
2005 Legacy GT
2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles
My WRX's Cardomain Page
Old 09-08-2003, 12:07 PM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Yea, I got mine for 56.95 but it still pulls to the right so I'm going back today after work to get it looked at again... It pisses me off when people can't do the job right the first time then I have to waste my time and gas to get them to do it right... Idiots!!!
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 09-08-2003, 01:34 PM
MAD4SVX
Just did mine for about $60.00, you might as well get the wheels balanced at the same time.
Old 09-08-2003, 02:33 PM
mbtoloczko's Avatar
sans SVX
$60-$80 is reasonable. You can fix the pull with an alignment, but it probably will not fix the shaking wheel.
Mychailo
Visit my locker
Old 09-08-2003, 04:13 PM
Bent wheel
Jerad
Mychailo is right, prices in this range would be reasonable for the work involved, but only bring it where they can do 4-wheel laser alignment, and the operator knows what he/she is doing.
Shaking could be a wheel out of balance, but if the steering wheel is shaking from it, then it is 90% more likely a bent rim, usually inside front.
Get the alignment people to switch your wheels front to back. This should be front right to rear right, rear right to front right, and likewise on the other side. NO criss crossing as you would on a rear drive car. Get them to balance the two you now have on the front, and then do the alignment. Unless you have bent both rims on the inner side, this should cure the shaking.
Old 09-10-2003, 03:53 PM
Thanks for all the help, I will probably go get the alignment and get all four tire balanced again. I havent had it on the road since late last october but i had the car jacked up for at least 75% of the time. But better be safe then sorry. Plus my security system shot the bed and i am trying to come up with the 100 bux for the module. again thanks for all the help.
Jerad
Old 10-15-2003, 08:19 PM
Earthworm's Avatar
Meow!
Just had mine aligned today - CAD$80 so about USD$50.
Was fairly straight except for excessive toe-in. Unfortunately my AVS db S2's have already started feathering.
As for pulling to the right, that's preferred (if only slightly) because if someone falls asleep at the wheel they will not turn into oncoming traffic.
Old 10-16-2003, 05:04 AM
svx_commuter's Avatar
I am using a shop that charges $80 for a four wheel alignment on a Hunter machine. With this machine the alignment is not dependent on the tires being new. Special fixtures clamp on to the rim of the wheels and then there is a procedure for removing errors that bent rims would cause.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
