Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 05-25-2007, 11:11 PM
Engine Build Progress and Questions
This is for anyone who needs questions answered or just wants to show us their progress on their builds... Good luck guys and lets get these motors runnin
Old 05-30-2007, 09:17 AM
cdigerlando cdigerlando is offline
Building the Perfect Engine.
Tom:
Great that you started this thread. I requested a subforum for this subject, so perhaps one of the moderators can move this up.
I am very interested in getting the type of bearings that you purchased. It sounded like you were combining bearings from two kits. I also know that you are doing engine builds for some other folks, so if you want to go in on splitting a kit let me know.
I'm still going to work on the copper head gaskets for the build. Have not heard crap from Mr. Gasket. Anyone else who is interested in gaskets let me know. I would kind of like to wait on the final order for gaskets since different folks may need slightly thicker gaskets from stock to make up for any milling required depending on the condition of each individual motor.
Done some investigating on ARP head bolts. 8 of our 16 head bolts are identical part numbers to the 4 cylinder engines, for which there are kits (12 in a 4 cyl kit). The other 8 are completely custom to the SVX engine. I may take some measurements and see if ARP will put together a kit for our car. Anyone who is interested let me know.
On the motor machine work front, I may go ahead and just plan on sleaving the motor with dalton ductile iron sleaves. If I can talk the shop into it I would at least like to get the deck semi closed. They were not thrilled with doing a fully closed deck. Mike thinks it would be too difficult as well.
Lets start posting and getting this stuff together.
See ya
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 05-30-2007, 09:22 AM
finally io have a day shift off... Calling the machine shop NOW!!!
Chuck, I am using the bearings off an ej22t motor... Need 2 sets of main bearings and 2 sets of rod bearings... Since I am doing 2 builds, I ordered 4 sets of main bearings and 3 sets of rod bearings... Mike has the part #'s just make sure you buy tri-metal bearings and not aluminum
Old 05-30-2007, 09:26 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
hey chuck whene are you going to bring the svx on the weds night meets?
QUOTE=cdigerlando]Tom:
See ya[/QUOTE]
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
Old 05-30-2007, 09:45 AM
I just ordered the "Rebuild Kit", from Subaru.
Part #10105AA060, and will post pictuers of the gasket kit when it gets here!
Old 05-30-2007, 09:50 AM
I know whats in them... I have ordered 2 in the past... I need to order another one
BTW machine work is all lined up and I need to find time to drop it off
Old 05-30-2007, 01:33 PM
I'm installing that set in my engine right now.
Old 05-30-2007, 01:44 PM
I think this is going to be my new favorite thread.
I want lots of pictures!
Old 05-30-2007, 01:47 PM
im not usually a picture taken while i am in the middle of this kind of stuff... BUT since I am going to take it slow and one step at a time... I may just snap a few
Old 05-30-2007, 08:08 PM
longassname's Avatar
Just some dude.
I second that. I'd love to see an engine build subsection under the mod mania forum and this could be the first thread in it....though the title of the thread should probably change to "omg somebody is building an eg33 and they live in the USA"
Originally Posted by cdigerlando
Tom:
Old 05-30-2007, 08:28 PM
Just some dude.
alternatively it could be called...
"OMG somebody is building an SVX engine and putting it back in an SVX"
Old 05-30-2007, 08:52 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tom,
I've got the Clevite bearing numbers for the rod and mains. Did you take a micrometer to your crank first, or did you just order the oversized bearing figuring you'd have the machine shop turn the crank to fit?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-30-2007, 08:53 PM
Just some dude.
I'm pretty sure Tom ordered standard bearings.
Bill, do you have your flow bench working?
Originally Posted by SVXRide
Tom,
-Bill
Old 05-30-2007, 09:00 PM
SVXRide's Avatar
Michael,
Interesting...can't wait to see what the clearances will be with standard bearings and a probably 100k+ mile crank...
Yes. Looking forward to running my heads on it once I get them back from the shop
-Bill
Old 05-30-2007, 09:04 PM
Just some dude.
Did you run a stock head yet? Want to run one of mine? I can send you one with a different valve seat configuration that is supposed to flow better to test....then you could send it back to me so I can do the exhaust ports and send it back to you to retest.
Michael,
-Bill
Display Modes Rate This Thread
Rate This Thread:
