Old 06-03-2012, 07:03 PM
dromano's Avatar
dromano dromano is offline
Re: Want to do a tuneup. Suggestions?
Originally Posted by SVX8588 View Post
Ok, just got to test drive after getting everything back together.
Here's some of what I found when working on it:
One of the rubber intake boots wasn't properly seated last time it was installed. This may have caused some of my problems since it could have been taking in unmetered air where the rubber was folded over.
Someone wrote "SVX" on my MAF! Probably not the original...
I also found this scratched in the mating face of the MAF:
My camshaft is named Rex
Those valve covers were dirty!
The air intake boots from the air box to the throttle body can be a royal PITA to get back on the throttle body. I cleaned my MAF a few days ago, used Vaseline to grease the connection, nope, a major, major PITA, finally held my manos just right & OMG, slipped right into place, what a crock!!!!!!!! Hate that job
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 06-03-2012, 07:24 PM
Would it make any noticeable difference in how the car runs?
I don't know?!
When I find it I fix it,
and usually do a whole other bunch of stuff at the same time.
IF I were to test before and afterward, and that was the only thing that I had done, I could give a better answer.
Old 06-03-2012, 07:52 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Ok, I guess I'll never know since I did a bunch of other stuff at the same time, too!
I'll see how she performs tomorrow morning. It's not supposed to get cool tonight (48 degrees), but it'll be a better test than when it's 70.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 06-04-2012, 06:38 PM
SVX8588's Avatar
Well, still a little hesitation, but much better than before. Maybe I should try the ECU crush now? anyone have any bad experiences with that?
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 06-05-2012, 07:22 AM
dromano's Avatar
[quote=svxfiles;705679]1)A folded snorkus is ALOT more common than you would think.
Tom,
What is a folded snorkus?
Old 06-05-2012, 09:08 AM
[QUOTE=dromano;705812]
Tom,
The first picture in post #31.
Old 01-24-2013, 05:36 PM
SVX8588's Avatar
Okay, bringing this thread back from the dead! My battery is dying so I've had the hood open frequently the past few days to jump it while I'm waiting for my new Optima Blue Top to arrive. Anyway, I noticed that my dipstick has continued it's old habit of popping up! I replaced the PCV valve when I did my valve cover gaskets, so now I'm not sure what the issue could be.
Other than it's just being a dipstick
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 01-24-2013, 06:17 PM
The PCV valve works great at idle and cruise, pulling the fumes from the crankcase, but when the pedal is down, the valve is closed, so the crankcase has to get rid of the blow-by using the small passages that you see here along the bottom of the air box, and if they are as gooie as the inside of the air box, they won't get all the pressure out. So the pressure goes up and the dick stick goes with it.
Old 01-24-2013, 07:04 PM
^ Makes sense. Also, the dipstick has a little O-ring near the top. If it's gotten very loose, then the dipstick might just be vibrating/wiggling its way up.
Old 01-25-2013, 03:53 AM
dromano's Avatar
[quote=icingdeath88;719036]^ Makes sense. Also, the dipstick has a little O-ring near the top. If it's gotten very loose, then the dipstick might just be vibrating/wiggling its way up.[/quote
I agree, the o-ring wears, ages & loses its ability to stay in place. Get a new o-ring.
