#31
Re: Built motor with ECUTune Stage 3 supercharger
You can still buy it, just return the parts.... Plus if you buy the motor and need any other pars I have laying around, I will give them to you for free.
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#32
*grr.* Wish I could. But the $$ went into my 4.11 5-mt, clutch, flywheel, short shifter, sticky tires and nuts and bolts. Good gawds id love to get a hold of that engine, but my auto is toast as of the new engine I swapped in.
#33
You are gona love the 5 speed.
#34
You would love it more with my motor
#35
$4,000 takes the motor and the meth kit
#36
Good lord. I am totally intrigued by this. I have a totally stock svx. What EXACTLY would I have TO DO to get this motor in my car and actually function? I do not want a 4000 paperweight that I have no idea what to do with. Last edited by steveherman; 07-04-2012 at 09:47 AM. |
#37
I am still waiting on pictures of this insanity. |
#38
At least, not the way I drive
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 Last edited by SVX8588; 07-04-2012 at 08:07 PM. |
#39
The temptation to do nasty things with the engine truly warrants a six speed transaxle. Things like this...
Similar, but not the engine advertised here; that's the Shadow Machine "only" on stock internals, 9psi, and without meth. The setup in this thread should punch a hole in the universe. ...or a hole in a lesser transaxle. Dang, I used to own an SVX that laid rubber....
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 07-04-2012 at 09:21 PM. |
#40
they can handle more horsepower than you think. Built 4EATs handle 800 horsepower. Axles, R160s, not so much. A six speed is the best transmission for a supercharged 3.3, but hey, if you want to get your feet wet, install it, drive it, (clean the drivers seat,) and replace the melted 4EAT when it goes boom!
#41
I have a 4.44 with svx torque converter. I am thinking how to make it actually run. |
#42
The main question that needs answered is whether it will run with the stock TCU, and the Hydra ECU paired together. If it can, then it's quite doable.
#43
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#44
Let's not mix up stock ECUs and Hydras, nor centrifugals and twin-screws. So many different animals, the zoo looks dull!
Disclaimer: The above post is on the internet. |
#45
Sooo... Who wants it?
Thread Tools | |
Display Modes | Rate This Thread |
