Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
just how many Racers are out there? Oh, crap! I can not believe that I played the race card.
Hi OT
I am thinking probably to use the 8mm(5/16) thickness, but 1/4 would probably work just about as well. Might break out the college textbook on heat transfer and see how significant the difference is. I notice that some of the manifold has to be ground down to fit around the AC line fitting at the DS front. Would using 1/4 eliminate that need? I will take a closer look tonight.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
If one did not care about the appearance it could be removed with a sawzall as long as they did not cut the AC line! The AC support bracket (the black flat steel plate) would need to be loosened if not removed for clearance, but again not a big deal. After the sawzall use one can easily smooth things out with a 1/2 round rough cut file.
I scanned in the OE gaskets and traced. You'd be surprised how ragged the edges of the gaskets really are!
1996 SVX LSi : Work in progress, future garage queen 2013 Acura TSX: Mistake |
Ill be taking a set right here! The sooner you have them done the better
Do you also have the file for the upper gaskets? The spacers will go between the injector stacks and manifold. Your file is from the gasket under side of the stack to the cylinder head. See OT's pictures above.
The only important spacer is between the injector stack and the head. If you block the heat there, it will not travel to the rest of the intake.
More volume to the intake runners and it also makes it easier to get to things like knock sensors, hoses and vacuum lines.
Hello?
Thoughts on fabing up 2 sets of 1/2-3/4 inch thick lower spacers (yeah, one for my racecar and one for OT's )? Thanks!! Bill
Once the program is made for the CNC, different thicknesses are just a minor change to the program, so not a big deal.
Question for OT or whoever knows: Installing upper spacers looks pretty easy. The lower ones look like a lot more work and difficult. Also..what about the EGR tube? Does it tolerate being moved 8mm upwards without too much trouble? For me, the difference in difficulty to make either the upper or lowers is not much. It's just a question of what people will buy. I would prefer to offer just one design, but if demand was there, I could do both.
Actually the lower ones are easier. The fuel lines are bolted to the intake manifold in a couple places so it's easier to remove the manifold, injector stacks and fuel system all in one piece than to take the manifold off by itself.
"Also..what about the EGR tube? Does it tolerate being moved 8mm upwards without too much trouble?"
I have streached the stainless steel tube several ways. The trick is to keep the flat surfaces paralell. On some I picked the intake manifold upward with an engine crane. Easy to do, and easy to mess up! I have also made an angle steel bracket where the bottom is lightly bolted into place, the angle steel is clamped in a big a$$ bench vice, I use a phillips screwdriver as a pry bar, and use carefully a blue tipped wrench to bring the tube up to red hot to allow an easy bend & streach, and using vice grips to ensure a paralell surface before things cool.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 11-18-2014 at 01:39 PM. |
#28
Soooo...
How are us mere mortals supposed to bend the tube?
#29
tube, smoob....block off plate FTW!
Bill
#30
Yep, EGR delete is the best solution!
Thread Tools | |
Display Modes | |
