Old 07-29-2005, 04:46 PM
pnyklr
I think I have the basic idea but I'm still a little iffy I'll wait a few days for the bigger pictures then see
Old 07-29-2005, 09:32 PM
Ok, and if I can, I will try to take some pictures for you as well.
Old 07-30-2005, 07:33 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Earl,
I found the whole How to. I zipped it up and it is in my locker. Pictures and html is included.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 07-30-2005, 10:17 AM
Thanks Doug. I will get it put into the How-Tos.
Old 07-30-2005, 11:05 AM
kuoh kuoh is offline
FYI: There is no need to remove the motor assembly if you just need to replace the mast. It can be removed and replaced from the top in about 10 minutes without any extra disassembly.
KuoH
Old 07-30-2005, 11:12 AM
Yes, unless the part has broken off inside, which is highly unlikely.
Old 07-30-2005, 02:27 PM
I have posted the new Antenna How-To. It is a little big to load, but it is worth it.
It is Here.
Old 07-30-2005, 03:32 PM
mohrds's Avatar
It is Here.
It is also on the SVX World Network site:
http://www.svxworldnetwork.org/howto...na/antenna.htm
1994 LSi (4/93)
2000 Ford Excursion
Old 07-30-2005, 04:39 PM
Doug
Did you just fix that? I could not get it to work before.
Old 07-30-2005, 05:14 PM
The tether is actually pretty tough, I don't think we've seen many reports of it breaking. Most people who have had problems have just had bent or broken masts, often from running through automatic car washes or very high speed runs on the highway.
You guys might want to consider updating your how-to's to include just the mast removal procedure at the beginning of the document, so people don't end up spending an hour disassembling their trunk for no reason.
KuoH
Old 07-31-2005, 03:34 PM
pnyklr
Mine its the black plastic on the outside the holds the mast that is broken
Old 07-31-2005, 05:29 PM
KuoH
I can do that. I will see if I can get to it.
Old 08-01-2005, 06:20 AM
dcarrb dcarrb is offline
Mine was. The antenna was stuck about halfway up (aided by electrical tape) when I bought the car. Looked as if the mast got bent while extended, and I guess the leader snapped when it retracted to the point where it was crimped. I just rewound the new one by hand and installed it with the mast in the fully-retracted position.
dcb
EDIT: Chris, after looking at your photo, I think I might try to glue the broken piece of plastic back into place with epoxy, then put a screw-type hose clamp around the assembly. I imagine it was broken by someone trying to remove the motor assembly without loosening the retaining nut topside; can't see how there could be much stress in that spot.
Old 08-01-2005, 08:39 AM
SubaSteevo's Avatar
No longer blue member
dcb
Actually it got broke in the mail and stupid me didn't have insurance on it
Since Chris has his non-working antenna as well, we're trying to make the best of it so he can get his radio working.
-Steve
01' MSM Lexus IS300
Old 08-01-2005, 08:26 PM
pnyklr
Ya I havent messed with the antenna recently.. I'm having another problem with the car now which is much bigger I think .. I'm not even driving the car ..
its sitting in front of my house
