How to fix antenna
I've got two.. mine doesnt do anything, its got juice though we tested it with a test light and the other the black piece is broken on the shaft.. how do I change it??
Oh the other antenna works perfect except for that black piece being broken
Do a search. Somebody had a pretty decent "how-to" with photos, but oddly enough, it's not in the How-To documents. I can tell you that, if the plastic take-up leader is broken, you'll need to pull the drive assembly and remove the broken end from the spool housing.
dcb |
You can check the SVXipedia on http://svx-iw.com/
I checked did a search using antenna ... no dice unless I am missing something... anyone have any ideas ?
I have it, but not on this computer. I will see what I can do for you. :)
Thanks I dont want to take it apart unless I know what the hell I am doing ;)
I will check, but I think I have the write up on the other computer at work. I will check and if so, I will put it in the How-To Docs and post again here to let you know. :)
Cool thanks
I just got the How-To put into the locker. The pictures are small and grainy, but I will work on getting the pictures replaced with better ones. It is the best that I can do right now. Lwin did this write up with the pictures, but I don't have larger pictures to put into the file. I will try to get them from him or take new ones myself. :)
Here is the link to the How-To. :)
Hey Doug, you have a few howtos right? You should submit them all to the SVXipedia.
Doug |
