#2566
Today I am searching for a replacement of the replacement driver side heated mirror
![]() I am contemplating buying a Class Glass hood ![]() ![]() ![]() What else? Right, I need to remember how to repair my automatic shoulder belt. I cranked it all the way back manually but it just retracted again.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
#2567
Remove the Air bag (4 T-30 or T40 security bolts (the ones with a hole in the center)), remove the steering wheel. Investigate the "clock spring" and connectors in the round plastic container.
"Peace is the flower of justice." |
#2568
MR2 pump? Inquiring minds want to know!
#2569
I am looking only for SVX parts.
![]() That's what you meant, right? ![]() Thanks big, appreciate.
#2570
Ah, gotcha. Thought you might have meant an electric powered hydraulic pump.
#2571
And secure the steering wheel so that it does not spin freely if you disconnect it from the rack.
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link |
#2572
installed block heater and replaced lower rad hose
also finally put back the skid plate
#2573
Had the SVX out for a spell of chores while the Outback was in for a new exhaust pipe back of the cat. I cracked the joint plowing through a frozen snow berm at the foot of the driveway two days previous. Parts ordered same day work completed by noon on Friday
Well, the SVX needed a photo op as well as a monthly run so over to F.A.G. Aerospace building for an unmistakable multi-message Winter photo. Washed and put away in garage until next month. Cheers, guys.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners. 1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project. 2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension. 1994 Emerald Pearl LSi w 2006 WRX 5 spd manual. 1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134 Last edited by Old Davy; 01-19-2015 at 06:32 PM. |
#2574
Never thought about the securing the wheel. getting it straight again sure is a pain in the rear.
#2575
#2576
And I bet that is exactly what happened!
#2577
Hey Nate...
#2578
Just sold the SVX to a coworker today.
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
#2579
Finished some work on our clear corners and rear center lights.
Removed the orange cup from inside the JDM clear corners and sanded and clear coated the lens using Sylvania headlight restorer. Photo attached. We will be using a bi-color leds (white and orange) for the bulb. Partially de-badged a spare rear center light assembly. Also sanded and clear coated the lens the same as the clear corners. Photo attached. We made our own internal "SVX" decal though you can find better ones from Retroroo http://www.indysworld.com/decals/. Photo attached below We also hope to do the same to the rear brake and side rear side marker lenses sometime
#2580
I autocrossed mine yesterday and either beat or matched most of the STIs' times.
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
Thread Tools | |
Display Modes | |
