Old 05-31-2012, 12:27 PM
Chris_'s Avatar
Chris_ Chris_ is offline
new timig belt +what else? oil leak too
Hi,
I have to put a new timing belt kit to my svx and I need to know what other parts I should change at the same time.
There are a small oil leak at front of the motor, it is motor oil but I dont know exactly where it is coming from??!! Maybe it is cam seals or might it be some else? Both valve cover seals are replaced a year ago and do not leak.
So If someone could write (or find somewhere) a whole list of parts and seals what I should replace at the same time as timing belt kit I would be very grateful. I want to stop that leaking oil !!!
I know this kind of list is somewhere here but where...
svx my94 vtd EUDM
-custom Spax coilovers
Old 05-31-2012, 12:28 PM
Re: new timig belt +what else? oil leak too
Cam and crank seals, check the torque on the oil pump bolts, and replace the water pump if it hasn't been done.
Old 05-31-2012, 12:45 PM
Chris_'s Avatar
What are part numbers of cam and crank seals? I have to order those.
svx my94 vtd EUDM
Old 05-31-2012, 02:19 PM
807045030 for the intake cams (2 needed)
806732150 for the exhaust cams (2 needed)
806733030 for the oil pump/crankshaft (1 needed)
Old 05-31-2012, 02:37 PM
Chris_'s Avatar
Thank you very much (again).
svx my94 vtd EUDM
Old 05-31-2012, 03:20 PM
svxwill's Avatar
svxwill svxwill is offline
when doing timing belt, also changed the Idler Pulley:
#1: 13085AA020 $100 (x2)
#2: 13073AA150 $55 (x2)
also beside the Cam seal there's Cam plugs that need replaced for oil leak
:1992 Pearl LS-L :182,000 (5/2010) – 210,000 (1/2013)
:MOD :Raybestio STS front rotors :Green air filter :Aero resonator :Magnafow muffler/dual tips :RE970 tires
DONATED :92 Claret SVX OTHER :07 Scion tC (wife) RIP :94 Blk Mustang GT :89 Slv 240SX
Old 05-31-2012, 03:53 PM
Which are typically included in a timing belt kit. But yes, if they aren't you should replace them as well.
That's the first part number I quoted.
blah blah blah 10 characters.
Old 05-31-2012, 04:28 PM
svxwill's Avatar
Y, that's correct
the part invoice i got just list it as Cam plugs with no part number
Old 08-22-2012, 03:07 AM
Chris_'s Avatar
Timing belt has been changed now and cam and crank seals are now replaced with new ones and...........oil leak has gone
Here are the seals that were replaced with timing belt kit:
svx my94 vtd EUDM
Old 11-01-2012, 05:13 PM
injuhneer's Avatar
injuhneer injuhneer is offline
- Bad Wolf -
Did you by any chance get the part number from the seal itself? I would be nice to add them to the parts cross reference.
-Mike O
Old 11-01-2012, 06:16 PM
Don't forget to change the oil pump O-ring.
Subaru oil pump O-ring 806919050
Display Modes
