new timig belt +what else? oil leak too
Hi,
I have to put a new timing belt kit to my svx and I need to know what other parts I should change at the same time. There are a small oil leak at front of the motor, it is motor oil but I dont know exactly where it is coming from??!! Maybe it is cam seals or might it be some else? Both valve cover seals are replaced a year ago and do not leak. So If someone could write (or find somewhere) a whole list of parts and seals what I should replace at the same time as timing belt kit I would be very grateful. I want to stop that leaking oil !!! I know this kind of list is somewhere here but where...
svx my94 vtd EUDM -custom Spax coilovers |
Re: new timig belt +what else? oil leak too
Cam and crank seals, check the torque on the oil pump bolts, and replace the water pump if it hasn't been done.
What are part numbers of cam and crank seals? I have to order those.
807045030 for the intake cams (2 needed)
806732150 for the exhaust cams (2 needed) 806733030 for the oil pump/crankshaft (1 needed)
Thank you very much (again).
when doing timing belt, also changed the Idler Pulley:
#1: 13085AA020 $100 (x2) #2: 13073AA150 $55 (x2) also beside the Cam seal there's Cam plugs that need replaced for oil leak
:1992 Pearl LS-L :182,000 (5/2010) – 210,000 (1/2013) :MOD :Raybestio STS front rotors :Green air filter :Aero resonator :Magnafow muffler/dual tips :RE970 tires DONATED :92 Claret SVX OTHER :07 Scion tC (wife) RIP :94 Blk Mustang GT :89 Slv 240SX |
Y, that's correct
the part invoice i got just list it as Cam plugs with no part number
Timing belt has been changed now and cam and crank seals are now replaced with new ones and...........oil leak has gone
![]() Here are the seals that were replaced with timing belt kit: 807045030 for the intake cams (2 needed) 806732150 for the exhaust cams (2 needed) 806733030 for the oil pump/crankshaft (1 needed)
-Mike O |
Don't forget to change the oil pump O-ring.
Subaru oil pump O-ring 806919050
