Old 03-02-2012, 06:38 AM
SomethingElse's Avatar
word words wording
Pistons,Rods,Cams for FI Engine
Im looking to build an engine I can call reliable. The stock blocks just dont cut it with a supercharger. Does anyone have these parts anymore? LAN stopped Selling them
Eric
Old 03-02-2012, 10:41 AM
Re: Pistons,Rods,Cams for FI Engine
Call cp.... or any other piston company... ir gonna pay but they will make what you desire... rods... eagle or better will make up a matched mset of 6 for u... valves... brian crower
Old 03-02-2012, 10:58 AM
Click the turbo project link in my sig, that should get you started.
The run down is this though:
CP pistons 9:1 CR forged pistons complete with rings and wristpins - $1100
6 take-off STi rods - $100
Cometic headgaskets - can't remember, I think they are like $130 now
Unless you want to rev a lot higher (which there's really no reason for) then that should do it.
You can also get Eagle H-Beam rods for a reasonable price, but you will have to contact them and get a balanced set of 6. They were unresponsive to my emails though.
Old 03-02-2012, 12:11 PM
Arias Pistons are also available, contact Nick Arias III at atomicspeedware.
Old 03-02-2012, 01:37 PM
word words wording
I went to rallispec.com and couldn't find the rods.
Will i be able to run my 12psi pully with that? I think I have meth injection..havent done much under the hood yet.
Also headwork cams,valves,springs...I need more input on the subject please if anyone has it.
Who?
Eric
Old 03-02-2012, 03:01 PM
I emailed them and asked if they had any and he hooked me up. Try to get some eagle ones first, it's the only place where I "cheaped out". I think you should definitely be able to run 12 psi with that, that's around what I'm aiming for.
Old 03-02-2012, 03:26 PM
I called them yesterday and they were out.
Old 03-03-2012, 08:58 AM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Manley makes rods too, that's what is in Jack's EG33 Impreza.
Bob Légère
EG33 Impreza tweaks
Old 03-03-2012, 09:10 AM
word words wording
OK I want to make sure I got it all...and where to get it from.
Cometic head gaskets - http://www.cometic.com
ARP head bolts - ??? (required?)
CP pistons - http://www.cp-carrillo.com
Aluminum crank/rod bearings - ???
Rods - rallispec.com (eventually)
as far as head work I think im going to rock the stock equipment. I haven't found any threads that says it wont work.
Eric
Old 03-03-2012, 09:13 AM
word words wording
I may have found some STI rods for next to nothing. From what I read they are forged..if they come on a stock 300hp engine I think they will work just fine for my application.
Eric
Old 03-03-2012, 10:07 AM
Cometic head gaskets - http://www.cometic.comARP head bolts - ??? (required?)
You can buy them directly from Cometic, at $126.00 EACH, or from M.A.T.
for less than $200.00 a pair.
Old 03-03-2012, 11:29 AM
This is my thinking as well. If 4 of them are good for 300hp, then 6 ought to be be good for like 450. From what I've read on the impreza forums, the rods are not exactly the weak point of the engines either.
If you don't need stronger rods, then stick with the lighter ones. Depends on what you're planning in terms of power. It seems like you're capped to 12 psi, due to the pulley setup. Maybe some ARP rod bolts are a good idea.
Rate This Thread:
