Old 02-27-2013, 10:35 AM
macadamianut macadamianut is offline
Total shutdown with elect power suging and fried fusible link
Arrgggh.
Hi all,
She left me stranded today. Total power loss, then 3 short surges then dead.
Yesterday, the dash telltales said battery, brake, abs similar to the last time I had to replace my alternator and battery. Would illuminate at startup and would disapper after rpm climbed. Slight whining coming from alt pulley area. Also yesterday I would get an intermittent airbag light.
After cold startup this morning, car idled down to normal 600ish rpm when it got off the bypass air, but then would kick back up to high idle randomly. Defrosters, lights, radio was on/running at the time. Car ran normally for about 20 miles and then the show was over.
Fusible link terminals actually "fused" themselves to the fuseblock. Wire is broken, so hopefully the rest of the system is okay.
Surges were crazy, blower motor at max, all lights, stereo. the whole event lasted about 3 seconds. Then nothing. Had to work the shift interlock to get it on the tow truck.
What happened? Alternator blew? Positive terminal short? How does one remove the pins now welded into the fuse block? Do I get a new link and solder it to the now permanent pins to check fixes?
Any help is greatly appreciated.
Thanks
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
Old 02-27-2013, 04:03 PM
oab_au oab_au is offline
Re: Total shutdown with elect power suging and fried fusible link
Originally Posted by macadamianut View Post
Arrgggh.
Hi all,
Thanks
Gee Mac you have some problems.
This one is the voltage regulator in the alt that has lost control of the voltage. All the lights that came on first were the first signs, as the voltage rose above 15V. When you started the engine in the morning the current changing the battery got high enough to blow the fusible link. Unfortunately The link only protects the battery, the rest of the electrical system is still connected. The alt keeps charging the rest of the electrical system to cause damage.
Depending on what was working at the time, and how high the voltage was, as to how much damage was done to the units, like ABS, ECU, TCU and all the relays that were on at the time.
One Arm Bloke.
Tell it like it is!
Old 02-27-2013, 05:38 PM
Sadly, these seem to be popping up a bit more often the couple years. Harvey, is it just a matter of the alternators and regulators nearing 20 years old or is there something more than that?
Old 02-27-2013, 06:04 PM
Well that, and the fact that the alt is mounted at the top of the engine shroded by the hood padding, that covers the vents to cool it, so when you turn the engine off, it gets a big heat soak into it, to cook the wiring and the reg.
One Arm Bloke.
Tell it like it is!
Old 02-27-2013, 06:15 PM
Is the regulator built into the alternator?
Old 02-27-2013, 06:17 PM
Yes it is.
Old 03-13-2013, 03:49 PM
John, I think this needs its own thread. Macs problem has not been resolved yet.
One Arm Bloke.
Tell it like it is!
Old 03-15-2013, 01:24 PM
Harvey,
As per your previous suggestions:
1. Tried unhooking the fuel pump relay (both relays, not sure which is the fuel pump) under the dash attached to the steering column which still popped fuse 16 when ignition switched to ON position. So no joy there.
2. All fuses out of underhood box. Replaced one at a time until interior ignition fuse #16 popped.
It appears that SBF #4 slow blow fuse #4 is the circuit the fault is on. The SBF's themselves are not blown.
Also to mention that the car will crank even though fuse 16 is blown. All accessories still work. Wipers, climate, radio, windows, hazards, etc.
The quick connect to the alt voltage regulator has two wires that both look like they had gotten pretty hot.
Hope this info helps to narrow things down.
Thanks,
Mac
Old 03-01-2013, 02:47 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
If this is happening more and more, it begs the question: what's a good prevention?
(I don't want to hijack, so maybe a post in "how to"?)
Old 03-01-2013, 03:03 PM
Replace your alternator....
the regulator is internal and is what causes this. So there is no prevention.
Old 03-01-2013, 04:40 PM
We can't prevent the regulator from failing. , but we can prevent it from destroying a lot of electrical components in the process.
If you look in this thread, at post 15, it shows how to reconnect the alternator wiring to prevent this trouble. Post 27 explains why it happens.
http://www.subaru-svx.net/forum/showthread.php?t=49727
It is not a difficult job to do, but good insurance.
One Arm Bloke.
Tell it like it is!
Old 03-01-2013, 03:48 PM
That was the exact motivation behind my question about the regulator above. Contemplating picking up a maniac alternator for the built engine. But they are a wee bit pricey...
Old 03-18-2013, 10:11 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
I actually had a manic alternator that had the regulator go bad after less than 60 days. Blew out my headlights and tail lights. My dash lit up like an Xmas tree and I figured my alternator belt had broken. Was surprised to see 18.5volts on multimeter. Manic will replace for free but my car is my daily driver and they did not even have cores in stock. I was told I needed to wait 2 weeks or more. So my $160 alternator became a $30 core at orielly.
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
