Total shutdown with elect power suging and fried fusible link
Arrgggh.
Hi all, She left me stranded today. Total power loss, then 3 short surges then dead. Yesterday, the dash telltales said battery, brake, abs similar to the last time I had to replace my alternator and battery. Would illuminate at startup and would disapper after rpm climbed. Slight whining coming from alt pulley area. Also yesterday I would get an intermittent airbag light. After cold startup this morning, car idled down to normal 600ish rpm when it got off the bypass air, but then would kick back up to high idle randomly. Defrosters, lights, radio was on/running at the time. Car ran normally for about 20 miles and then the show was over. Fusible link terminals actually "fused" themselves to the fuseblock. Wire is broken, so hopefully the rest of the system is okay. Surges were crazy, blower motor at max, all lights, stereo. the whole event lasted about 3 seconds. Then nothing. Had to work the shift interlock to get it on the tow truck. What happened? Alternator blew? Positive terminal short? How does one remove the pins now welded into the fuse block? Do I get a new link and solder it to the now permanent pins to check fixes? Any help is greatly appreciated. Thanks |
Re: Total shutdown with elect power suging and fried fusible link
This one is the voltage regulator in the alt that has lost control of the voltage. All the lights that came on first were the first signs, as the voltage rose above 15V. When you started the engine in the morning the current changing the battery got high enough to blow the fusible link. Unfortunately The link only protects the battery, the rest of the electrical system is still connected. The alt keeps charging the rest of the electrical system to cause damage. Depending on what was working at the time, and how high the voltage was, as to how much damage was done to the units, like ABS, ECU, TCU and all the relays that were on at the time. Harvey. |
Harvey. |
Is the regulator built into the alternator?
Quick update,
New (probably crappy reman) alternator in place and fusible link replaced = blow ignition fuse over and over again when turning key to start. Indicative of anything in particular? Short to ground somewhere? Thanks |
Start with the slow-blow fuses in the un/hood box. The big square ones. Do you have the WSM? Harvey. |
Harvey,
Does WSM mean service manual? When cranking, fusible link gets hot and no start as it eventually blows the fuse. I am wondering if the ECU is toasted dark. Lights, wipers, climate, cruise switch and radio all working. Battery tests okay, voltage wise. Doesn't the ignition fuse also do the restraint system. Is that why I had the random airbag light? Maybe a seperate issue. Also new alt is a Bosch 95 amp. Tried to check codes but no light and I'm sure they were all erased. Hope this helps narrow things. Thanks |
Harvey. |
Harvey,
Thanks. Have not seen the power light. Fuse that blows is the ignition fuse. Have not run tests on ECU yet. Will try that or try to find another ECU. |
So If the fuel pump won't run, even with another ECU have a look at that. Harvey. |
(I don't want to hijack, so maybe a post in "how to"?) |
the regulator is internal and is what causes this. So there is no prevention. |
