Old 05-23-2012, 07:04 AM
Frogman75 Frogman75 is offline
Please Help..Cranky Crank Pulley
My '92's original crank pulley just separated and I'm in need of a replacement....I do not want an undersized pulley or anything too fancy...saw one or two on ebay made of lighter metal and all one piece, rather than original that seems to be two parts held by rubber which has dried up and cracked...will this replacement by obx fit wihtout any problems?
Any suggestions, opinions, advice, etc. much appreciated....You have saved my svx before (rerouted brake line, mas filter, etc.) and I look forward to your replies.....Frogman75
Old 05-23-2012, 08:11 AM
Re: Please Help..Cranky Crank Pulley
Yes the one piece will fit up fine....some brands will rub the timing cover a bit, but nothing worth worrying about.
And the pulley off any Impreza Forester Legacy (4-Cylinder) is the same and will work on the SVX.
Old 05-23-2012, 08:48 AM
OK- Thanks,,,noticed that when crank pulley split and seperated that it left a small tear/hole in black timing cover behind it....should I care about this? patch it with glue, etc. ?? Again, thanks for sharing your svx wisdom...Frogman75
Old 05-23-2012, 10:37 AM
if you take off the timing cover and put duct tape on the back side you can use an epoxy or truck bed liner on the front to seal the hole and then remove the tape. would be advisable to fix it so you don't get any debris onto your timing belt.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1956 Plymouth Belvedere - Daisy
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 05-23-2012, 01:52 PM
That is a pretty clever idea actually.
But yes, not necessary to worry about small holes in the timing cover.
Old 05-23-2012, 12:53 PM
The timing covers get grooves worn in them (and eventually holes) under normal conditions. I wouldn't worry about it.
