how to remove sunroof
i'm trying to remove the sunroof on my parts car, is it possible to take it off when it closed? there's not power harness to the car so i cant open it. any input would be nice.
Re: how to remove sunroof
If you can get to it's wires then you'll be able to jump it with a regular car battery and open it that way.
Yea when I helped get one out of a parts car we had to put in a battery and open it, wouldn't come out otherwise. I'm sure you're industrious enough to figure something out.
use a standard car battery. Get 10ft+ test leads. Hook it directly to the wiring for the sunroof. One way will power it to close while hooked up opposite should open it.
Can't you use the Allen wrench normally used to manually crank it closed in an emergency?
Glenn
i'll take a look
