How's your OEM jack holding up?
Kind of hard to see, but the main pivot pin is shearing through on mine. It didn't drop the car, and fortunately I was lifting it high enough to put some 2x10's under the tires (perks of a lowered car). But either way, she's done. I might replace that pin with a good high strength bolt. One thing I like about the SVX jack is that it's pretty low profile and can get under my car. Or maybe I'll just look for a small aluminium floor jack.
Re: How's your OEM jack holding up?
I used to carry a lightweight aluminum racing jack in the trunk for emergencies, but it took up too much room. Stays in the garage now.
Now I just carry a 1.5 ton scissor jack and a 12" x 12" piece of deck board for support on uneven ground. My OEM jack has never been used and will stay that way. I NEVER felt comfortable or safe with that design. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-22-2013 at 06:11 AM. |
Two out of the four I've owned have dropped a car and bent. My driveway and parking area are sand and gravel, very uneven and many soft spots. I try to avoid using the two remaining good ones. When I do I put a large board underneath.
They're small and handy and lift quickly but are very unstable. They need a bigger foot. |
Yep, I bent an OEM one too.
After my original (cheapo) floor jack failed, I replaced it with one of those big 3 ton jacks. I feel so much better now with a decent jack. As bad as that cheap jack was, it was still better than the OEM. That OEM jack is an accident waiting to happen, scary.
It is dangerous to use. I have heard of more problems than it working. I would get another jack that can be trusted.
Oh don't worry, I never use that one for any real work on the car. I have my 3-ton floor jack that's served me well since I bought my car. But it's about 100 lbs, so I definitely need to find an alternative for roadside emergencies.
Disconcerting to consider how many such maginally-engineered items as the SVX jack make it to the marketplace. dcb |
There was a time, when I was first learning to work on my own cars, that I used the stock jack relatively frequently. It didn't take long before I bought a real floor jack, though - the one that came in the trunk is downright scary!
here is a good replacement jack for a decent cost has good review
Where is a good place to store it, when your not using it? http://www.walmart.com/ip/Torin-Jack...roduct+Reviews Last edited by kjoyes; 03-24-2013 at 01:50 PM. |
