upper cam rubber seal rubber plugs
Do these pop off??i can get a screwdriver between the plug and the head but looks like they'll tear if i pry them away.
Re: upper cam rubber seal rubber plugs
There's metal inside them, so it has enough structure to come out in one piece. Don't plan on reusing them though.
I usually put a flat head screwdriver against the side of it and give it a few solid taps with a hefty hammer. Pops them out pretty quick.
Are there no seals for the upper cams?popped the cap off...no seal
the intake cams use "plugs" as seals, so yeah just the black plugs, replace those and your good to go!
kewl...thxxx
engine is back together,,i hate to dry start it since oil pump was off.. fuse i can pull so it'll pull oil around w/o starting?
I can't think of anything easy to pull that would let you do that. You can jumper the starter solenoid to get the starter to turn though. That would do it.
maybeee..i can just bump it around a bit...
You could just unplug the 6 injectors and crank the engine a bit. The only problem doing it this way is that you are moving the internals while priming. It's not the best method, but I did it a similar way and did not have any issues.
<<You could just unplug the 6 injectors and crank the engine a bit. The only problem doing it this way is that you are moving the internals while priming. It's not the best method, but I did it a similar way and did not have any issues.>>
i dont know of any other way to get oil around the engine without moving the oil pump huh? pull the ignitor plug and save yourself from pulling an extra 5 wires. or if you can fit your hand down there, pull the cranks sensor plug.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
