Thread Tools | Display Modes |
UV Coating beginning to delaminate from front grille and headlamps. Solution?
So as some of you may know, our SVXs came with a UV coating on the headlights and grille which prevent them from yellowing. Once this coating wears off whether from peeling, or from being "sand blasted" away by highway driving, the headlamps begin to yellow. Today I noticed that mine is starting to delaminate at the very top center of the grille. I can't stand the thought of having yellow headlights and am wondering if anybody has any input on how to stop this process from getting worse. Perhaps the only option is to buy new headlamp and grille units?
Re: UV Coating beginning to delaminate from front grille and headlamps. Solution?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Mike,
Check this thread by Crazy_pilot. He found a company which professionally restored his headlights. Took them completely apart installed new projector lenses etc. Polished the outside of the lens completely and applied the Lamin-X film. http://www.subaru-svx.net/forum/show...red+headlights The website to the company is HERE Cheaper than buying new lenses. I am not sure how the Lamin-X would work on covering the contours of the grille. That may be strictly a replacement issue on the grille.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
For Laminix a heat gun would be necessary to get it to mold nicely to the contours of the grill, but otherwise should not be a problem. It will be a little more pricey to get a piece long enough to cover it though.
Since Will did my headlights they haven't yellowed at all, they're still just as clear as my JDM corners. I polished the grille at the same time I installed the headlights and it's yellowed badly since then, so obviously Will's clear coat and the Lamin-X are doing their job well.
![]() Another consideration is that if I recall, new headlights aren't THAT expensive from Subaru. This set is not anywhere close to being unusable, however I figure I may buy a set to keep around for when these no longer become tolerable. Another option would be to have a set of used headlights refinished that are already in otherwise poor condition. I'm just brainstorming, I guess.
They are not too expensive. I have a new set still in boxes (as well as the waterfall grill) just in case. They were about $675.00 a pair, and are getting harder to get.
Even new sets have the problem of the projector lens chipping around the edges of the housing and causing white glass dust to accumulate inside the housing. I may send my current "perfect" set to prolightz and have them disassemble them, install a new set of projectorlenses in a bead of clear RTV to cushion them, and get rid of the residual glass powder. .
