Lug pattern
Hunting for wheels as I'm on small stuff now (7x16, 42mm running 205/55). I planned to go 7.5x17, 55 (or close) 225/45.
I've found some sets that are reasonably close but what's up with the lug nut dimensions? Exactly what measure are they? The thickness? The lenght? The spacing between the nuts?
I got my girl, I got my glass, I got my car and I'm ready to f... |
Re: Lug pattern
5x114.3 or 5x4.5 spacing 12x1.25 lugs 57.1 bore size
Good reference guide here:http://www.roadkillcustoms.com/hot-r...aru&Models=SVX Last edited by Blacky; 04-18-2012 at 11:06 AM. |
Re: Lug pattern
Thanks, that will come in handy.
Is there any alloy except stock that fits perfectly? I just want 16" or 17" x7.5 with 55mm offset.. but it seems more or less impossible to find so small diameters with that offset.
Re: Lug pattern
I would think if you get a 5x114.5 wheel it should fit, you just need the correct offset.....dont quote me on that though XD
Re: Lug pattern
(It says the common measurement for Subaru is 5X100, but the SVX, Tribeca, and STi are among the exceptions and are 5x114.3.) Something that does rarely come up is the actual size of the nuts themselves. Some rims have designs that limit the space around each actual lug nut, so very big lug nuts (or the wheel lock key) won't work. The stock SVX lug nuts tend not to work with aftermarket rims anyway, though, so just make sure that whatever rims you get you also get lug nuts that will work.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 04-18-2012 at 06:45 PM. |
Re: Lug pattern
The STI BBS wheels are a perfect fit, 17x8 in the 5x114.3 bolt pattern. They come standard with 225/45/17 tires, but will accept 235 or 245 width just as well.
As mentioned, you'll need a set of 20 lug nuts in 12x1.25mm thread size, with the standard 60 degree cone. Tuner nuts are fine, but the ones with an internal hex socket should be avoided like the plague.
Re: Lug pattern
Great link, Icing.
Crazy, if it's 8 inches wide, what's the offset? It's the offset that has me worried a bit. I know this is obviously controversial but there appears to be two camps when it comes to offset. Some say it doesn't matter as long as the wheel fits fine while others say it actually affects how the car drives. Remember, my daily drive includes a mountain pass with some extreme cornering, bad roads and high speeds
Re: Lug pattern
The STi BBSes are a perfect fit on the SVX. I have them on both my cars, and they are just right. There were some (in the US at least) that were 5x100 (2004 models only), and most were 5x114.3 (05-07). Double check that you get the right ones. The "two camps" applies to other cars. The SVX, with it's rear wheel bearings issues, requires that you stay pretty close to stock. It's not so much an issue of how it will affect how it drives, but rather, how much stress is applied in what direction to the wheel bearing.
Re: Lug pattern
The offset of the BBS STi wheels from 2005-2007 is +53mm, which causes us no problems whatssoever
Re: Lug pattern
On the other hand, it's 8 inches wide?
I got my girl, I got my glass, I got my car and I'm ready to f... Last edited by jetboy; 04-20-2012 at 12:59 AM. |
