Engine temp gauge
Is everyone's temperature gauge needle this high on the scale during regular driving? Or is it time for a new temp sensor?
It reads this high ever since I bought the car. There's no coolant leaks, no other noticeable heat problems, and ambient temperature hasn't been over 40*F for the past month or so. Also, car usually idles around the RPM shown when in neutral, but I figure that's probably my bad TPS.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
Re: Engine temp gauge
That's perfectly normal. That's where both of mine sit normally.
My temp is always on the dead middle.
I didn't try neutral but idle at between 500-900, depends how long I've driven. Generally lower when properly hot.
I got my girl, I got my glass, I got my car and I'm ready to f... |
Looks like mine. Where did you think it would be? I do not get good heat from the heater til it gets that high.
I gathered teh idle speed of this engine at operational temperature is supposed to be around the 500 mark? Does this say anything about the engine's health?
I'm assuming my high idle is a combination of a bad TPS and a bunch of cracked 21 year old vacuum hoses in my engine bay.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) Last edited by EdWindows; 01-03-2013 at 09:01 AM. |
Better to ask than to just assume it's ok. Also important to know is that it takes a relatively large change in temperature to move the gauge from that spot. That means even a little bit above where it normally is means a lot more heat.
