Fiberglass hood and hood struts
I just bought Rebecca's old fiberglass hood (I love it, thanks Rebecca ) but I have noticed that there are no holes in it to attach the hoodstruts.
Now, I have replaced the OEM struts with some aftermarket ones as outlined by Jon's instructions and they have been working perfectly on my old hood. My question is, can I drill holes into the crossbeam (for lack of a better term) on the underside of the hood to attach the hoodstruts? With the entire thing being fiberglass I wasn't sure if that would be too much strain on it and break while trying to close the hood. Does anyone have any experience on this that I could benefit from? Thanks
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Re: Fiberglass hood and hood struts
I think that to be safe, you might get a hood prop like what comes on Outbacks/Legacys.
I am not saying that its not possible, I am offering a cheaper alternative, with less chance of failure.
PM svxfiles. He has a lot of experience in this area.
A set of worn-out stock hood struts would be sufficient on the lightweight hood A mini vise grip on the shaft in the open position would help if they weren't strong enough
It's the chance of failure i'm worried about lol. I honestly like having working hoodstruts again and I would like to keep using them. These do seem stronger than the OEM ones though so I could see it causing an issue with the fiberglass hood (snapping it in too the first time I try closing it is my biggest fear the) Maybe I could buy some weaker struts (same dimensions as these) to use on it. It wouldn't take but a minute to swap the mount onto it now that I've already done it once. Any thoughts?
I remember looking at Young Tom's Shadow Machine at Reading and talking about the hood with him. He told me he used a set of worn out hood strut on the fiberglass hood. A set that would fall on a normal hood was perfect for the lighter weight of the fiberglass. I might still have my old set if you want them.
I'm in a situation similar to yours. I have a carbon fiber hood sitting in my garage, and the hood struts on one of my cars no longer hold the stock hood up very well. I am going to give those a shot and see how it goes, and if they seem too strong, then I'll probably go the hood prop route.
Actually it had quite a large opening in the hood, the freaking engine was sticking out.
I made a really nice hood prop for the Killer Tomato when that hood was on the car. It's nice to have hood struts but I'm fine with just a hood prop. I don't know how many times the hood on my claret would randomly fall (sometimes on my head! I hear concussions are easy to get!). Glad you like it!
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
Originally it did not have a big freekin hole in the hood.
Ok, took some measurements and the fiberglass hood is 22lbs. The stock hood is right around 45lbs.
When I did the new struts I got the GNSI 2250-90's which seem to fit pretty well. The hold 90lbs with an expanded length of 18" and a compressed length of 11" They do have struts with the same dimensions that are just weaker. They have 30lbs and 45lbs (http://www.spdhardware.com/catalog/G...20Gas%20Spring) I'm thinking I could do one of those. That would exert less pressure on the hood when closing it, but still be enough to hold it up. I'd probably go with the 30#'s. What are your thoughts?
