lost my crank pulley
Has anyone ever had this happen. Went to move my car this morning, and heard a weird noise and my crank pulley separated in half, one piece on the driveway floor the other still in the car. All dash lights on, loose belts, etc. Should I buy a new one, seems the logical way to go with the oem ones. Also, dont some legacy model crank pulleys fit our svx's.
Re: lost my crank pulley
EJ22 and EJ25 crank pulleys fit.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Thanks for the info. Called dealer, list is $189
Yep, get a new one, there's no saving the old one. This is a well enough known failure.
An alternative is the lightweight aluminum one-piece pulleys. They can generally be had for cheaper than OEM.
I bought a 1-piece lightweight one (not installed yet). Any performance gain is too minor to notice, but they have the added advantage of being 1-piece, so they can't ever fall apart. The kartboy one I got is also cheaper than a new OEM one, and also anodized aluminum, so it can't rust. Plus it's black, so it blends in well.
http://www.oakos.com/Merchant2/merch...egory_Code=200 These guys have it for $90, but I think I got it cheaper. Shop around.
You can also try on your local nasioc chapter to see if someone that has upgraded to a 1 piece is selling their stock pulley. They usually go for around $30.
Thanks fellas, I will keep that in mind.
I have one of the Perrin pulleys. Weight = 1.2 lbs
Got it from these guys. http://www.maperformance.com/perrin-...ey-subaru.html It was at my door 4 days after I ordered it, not to shabby. I have not installed it yet, but I had this same pulley on my RS and never regretted it. Last edited by Lookin4SVX; 12-09-2011 at 09:04 PM. |
will this Dorman pulley fit. New $44.99 free shipping on fleabay
http://www.ebay.com/itm/Harmonic-Bal...item5645d3cd98
Which if any of these two part number pulleys will fit
12305AA242 12305AA210
Actually you were pretty lucky, that pulley could have fallen of in Bristol or while you were driving .
wouldn't that be something if that solved your idle problem |
Conn, yes that would be something if it solved my idle, but Im sure its totally unrelated, wishful thinking though
Well, cmon already, can someone let me know if either of those two pulley part numbers listed in this thread will fit. I need to get one asap.
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-10-2011 at 02:05 PM. |
