Old 08-27-2013, 04:54 PM
Green1995SVX's Avatar
UV Coating beginning to delaminate from front grille and headlamps. Solution?
So as some of you may know, our SVXs came with a UV coating on the headlights and grille which prevent them from yellowing. Once this coating wears off whether from peeling, or from being "sand blasted" away by highway driving, the headlamps begin to yellow. Today I noticed that mine is starting to delaminate at the very top center of the grille. I can't stand the thought of having yellow headlights and am wondering if anybody has any input on how to stop this process from getting worse. Perhaps the only option is to buy new headlamp and grille units?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-27-2013, 07:15 PM
Re: UV Coating beginning to delaminate from front grille and headlamps. Solution?
If you want the perfect look I'm sure you do, I think it's something that has to be stopped before it starts, by covering it with LaminX or something similar. Because once it starts peeling away, it's probably too late to stop it.
Old 08-28-2013, 05:41 AM
Mike,
Check this thread by Crazy_pilot. He found a company which professionally restored his headlights. Took them completely apart installed new projector lenses etc. Polished the outside of the lens completely and applied the Lamin-X film.
http://www.subaru-svx.net/forum/show...red+headlights
The website to the company is HERE
Cheaper than buying new lenses. I am not sure how the Lamin-X would work on covering the contours of the grille. That may be strictly a replacement issue on the grille.
Old 08-28-2013, 08:28 AM
For Laminix a heat gun would be necessary to get it to mold nicely to the contours of the grill, but otherwise should not be a problem. It will be a little more pricey to get a piece long enough to cover it though.
Old 08-28-2013, 09:51 AM
Mike,
Hey Mike,
Since Will did my headlights they haven't yellowed at all, they're still just as clear as my JDM corners. I polished the grille at the same time I installed the headlights and it's yellowed badly since then, so obviously Will's clear coat and the Lamin-X are doing their job well.
Old 08-28-2013, 11:07 AM
Originally Posted by Crazy_pilot View Post
Hey Mike,
I'm in the car business and actually have two local "headlight" guys that come around who do fantastic work. I just didn't want to go down that route since my headlights and grille are otherwise "like new." I had the headlights refinished professionally by one of the local guys on an A6 that I used to own, and they stayed like new for the remainder of the time I had the car.
Another consideration is that if I recall, new headlights aren't THAT expensive from Subaru. This set is not anywhere close to being unusable, however I figure I may buy a set to keep around for when these no longer become tolerable. Another option would be to have a set of used headlights refinished that are already in otherwise poor condition. I'm just brainstorming, I guess.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 08-28-2013, 12:11 PM
They are not too expensive. I have a new set still in boxes (as well as the waterfall grill) just in case. They were about $675.00 a pair, and are getting harder to get.
Even new sets have the problem of the projector lens chipping around the edges of the housing and causing white glass dust to accumulate inside the housing.
I may send my current "perfect" set to prolightz and have them disassemble them, install a new set of projectorlenses in a bead of clear RTV to cushion them, and get rid of the residual glass powder.
Old 08-28-2013, 04:53 PM
michael's Avatar
michael michael is offline
What Potholes ???
'97 grille and glass headlights.
Though you're still stuck with the corners, I don't think you will rack up enough miles to mess them up.
Wanted: Steering Wheel
Old 08-28-2013, 05:48 PM
A matter of personal taste. Some like the "smiling waterfall look" and some prefer the "catfish waiting for a hook" look.
Same with wheels and spoilers.
I've had them both, back in 2001.
Waterfall won.
Old 08-28-2013, 06:05 PM
michael's Avatar
What Potholes ???
I keep one around in case I get an itch. I prefer chrome though.
Old 08-28-2013, 06:07 PM
michael's Avatar
What Potholes ???
Vehicle wrap laminate might make a great flexible laminX alternative.
Old 08-28-2013, 10:41 PM
kingbobdole's Avatar
kingbobdole kingbobdole is offline
On the cheaper end of things I restored my headlights using the BG headlight restore kit. Comes with some sand papers, wet sanding magic fluid, cleaner, and an epoxy type over coat. Makes the headlight look brand new, but doesn't always last. Used to do the job on my father's ford focus which has huge headlights and after three years the epoxy coat would start to flake at the edges and I'd simply do the job over again. I recently got a headlight out of a junk yard that had been badly yellowed. It's the drivers side and I'd been having trouble finding a non broken one, so I took what I could get. Didn't get a before pic, but after it looks like this.. Don't mind the carbon fibber wrap.
Because of how the grille is made, it will work there too. Not the most correct fix, but the best value.
~Phil
94 Front Wheel Magic SVX
89 XT-6 EZ30 6 speed
79 Subaru FE
97 Impreza sport flintstone edition
78 BRAT!
76 Alfa Romero GTV
Old 08-29-2013, 12:18 AM
flamestone's Avatar
flamestone flamestone is offline
Don't panic... even if it yellows, you can generally still bring it back.
The funny coincidence is that I was restoring one just yesterday. I did just half and took photos.
So here's the evidence:
Thankfully, here in Aus we have glass headlight lenses, so no yellow.
Old 08-29-2013, 12:28 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
So what country has glass & LH drive - why not buy that option of headlight ?
It may mean pulling apart to fit to the USA style lights
- here in NZ we have different type of lights (H3 Vs 9000series) etc. we also drive on RHS so that option is out.
Old 08-29-2013, 01:37 PM
Originally Posted by SURTEESS View Post
So what country has glass & LH drive?
GERMANY.
