Will 235/45/17 rub on the SVX?
My rims are dented badly, and I have the option of buying a set of jdm STI wheels off an acquaintance with tires for $500. I just paid almost $1700 for books/subscriptions and I was putting off buying anything for the car until I paid off my tuition and graduation fees, but I need front tires and at least 2 rims in order to continue driving to school and work . I figured for not much more these might be a better investment if the 235/45/17s would fit without rubbing. I'd appreciate anyone with some input.
Re: Will 235/45/17 rub on the SVX?
According to the tire size calculator http://www.1010tires.com/TireSizeCal...?action=submit
They should be a close size fitment. Now depending on the rims offset and width is where you would find trouble with rubbing. Get a rim that has the correct fitment. |
Yes, you'll be fine. Make sure the wheels are 5x114.3, not 5x100.
and I now have 245/45/17s on my Claret without rubbing. You should be fine.
your looking at 5mm wider and profile is lower than before so speedo will be slightly out - but will run on SVX no probs.
Useful link for cross matching tyres and rims http://www.rims-n-tires.com/rt_specs.jsp cheers bruce |
The tire is about 1/2" TALLER than the stock tire and will be harder/harsher on your transmission by slightly changing the final drive ratio... Since my Claret has a MUCH lower first gear ratio because of the 4.44s its not a problem for me.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 02-18-2010 at 12:37 PM. |
Thanks for the info everyone, ideally appreciate it. They're jdm sti wheels, and the offset are Typical of oem wheels, +48 or something. My trans is crap, I'm jet waiting for it to take a dump to do a 4.44 swap or the like. Seems like I chose a bad time to be a SVX owner too, what with AWD closing down and me trying to make ends meet forthe next few months. I think I'm going to be spending a lot of time here in the future.
We have stock wheels if you need/want them. Just FYI. I won't have room for them soon.
1991 SVX L JDM |
is there any logical reason why
rims are measure in inches tyres are metric offset is metric PCD is either imp or metric and we still measure pressure in PSI in metric countries! Last edited by viking64; 02-20-2010 at 09:01 PM. |
The actual numbers are as follows; The 235/45/17 tire will be about 11.9mm taller than the stock 225/50/16 tire, with a spedometer READING 98.1 mph of kph when the vehicle is traveling at an actual speed of 100 mph or kph.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 02-20-2010 at 09:55 PM. |
yes, my bad - I was using 60 instead of 50 profile as the stock tyre and thought that they should be pretty similar in size and realised my mistake.
Mind you even with stock rims I reckon my speedo is not correct - maybe 5 - 10 km under on the highway |
