Old 03-26-2003, 12:43 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
found my vibration(5spd)
gee...im not completely sure but maybe this would be making the banging noise i get on load ? I have to put some spacers in the tranny, the crossmember isnt low enough to accomodate teh shifter, shouldnt be to hard to fix i just have to get some time in this week to get it taken care of with my friend.
phil
~Phil
Old 03-26-2003, 01:26 PM
Phil,
Try putting a 3/16" spacer under the carrier bearing mounts, to lower the driveshaft in that area.
It'd be easy to do without much dissasembly.
Old 03-26-2003, 01:41 PM
Phast SVX's Avatar
Huck,
Even better plan....ive put some time away thurs night for this hopefully.
thanks a lot
phil
~Phil
Old 03-26-2003, 06:48 PM
Subafreak's Avatar
Superbeast
Damn I was hoping you found the problem with my vibrating.
Did you do something different with the smallcar kit? I don't understand why it would be hitting esp. with the STI mount holding the tranny in place.
Old 03-27-2003, 11:02 AM
Phast SVX's Avatar
it just literally dosnt fit. All my parts are from an 03 forester, all i can think if is that they modified the shifter assy a bit, either that or my crosmember is holding the trans too high. Anyways ill let you guys know when i get it worked out, which will hopefully be tonight
phil
~Phil
Old 03-27-2003, 03:50 PM
AutoTchr AutoTchr is offline
Time for me to fess up.....
*swallowing pride*
I have also been battling a vibration. Mine is not related to the shifter. My vibration comes on suddenly just about 40 mph and does not change with speed. It was not there prior to the conversion and is not a wheel.
I have had it on the hoist, pulled all four wheels off etc etc. Vibration is still there. The driveline has been in the shop 3 times now. It checks out fine. No extreme JWAs maybe about 1 degree. Driveline shop "thinks" that the CV joint is worn out. But by the time I replace that I will have a 300.00 driveline that may not fix the problem.
I have tried shimming the transmission up and down to no effect.
Today I am picking up a nearly brand new driveline out of an H6 that my supplier *says* will work. Identical in everyway except maybe 2" longer in the front.....we will see.
ASE Master and L1 cert. Discounted Repairs
I feel a lot more like I do now then I did before.
92 SVX 5spd, (sold),92 SVX Teal, 67 Mustang 351C 5spd, 00 Galant.
Old 03-27-2003, 08:00 PM
phooyee
All I managed in doing was burning up the gas to go pick up the part. The two drivelines are way different.
Old 03-27-2003, 08:12 PM
Phast SVX's Avatar
i shimmed the midshaft bearing and the trans with washers and got rid of my vibration.....im very pleased with it now. Now onto important things, when you say it dos nt change with speed how about on or off load does it change?
~Phil
Old 03-27-2003, 08:15 PM
Phast SVX's Avatar
Re: Time for me to fess up.....
Originally posted by AutoTchr
*swallowing pride*
i have two front axles from my conversion becuase i had to use forester axles, the 03's have differnt connections. 100 plus shipping and their yours for both. pm me
~Phil
Old 03-27-2003, 08:17 PM
Good!
On mine, at sixty you can push in the clutch and the vibration is better, but still there.
I could not see shimming the center because it would increase the angle that the CV has to work at. But I will give it a try. Thanks. Oh and about how far did you shim it?
Old 03-27-2003, 08:22 PM
It wouldn't be the driveshaft (u-joints) would it?
Just guessing here.
Old 03-27-2003, 08:28 PM
Phast SVX's Avatar
3/16inch on the midshaft bearing nad two washers on the trans.....im not joking thats all it took
phil
~Phil
Old 03-27-2003, 08:50 PM
Phil,
Was your vibration similar to mine or was yours because the driveline was contacting the shifter?
U joints seem fine.....
Old 03-27-2003, 08:52 PM
Oh and when I said CV I was referring to the CV in middle of the driveline......Let me guess your an ex salesman??
Old 03-27-2003, 09:26 PM
Phast SVX's Avatar
lol well you see, i have to pay for this thing called college, so im trying to make money anyway i can...well almost
phil
~Phil
