Old 02-07-2003, 09:05 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Ignition lock
i have a new key cut at the Subaru dealer from the VIN. The key works the door locks and the trunk, but doesn't work in the ignition. I have another longer silver key (non black top) that works in the ignition, but not the doors and trunk. Apparently the ignittion lock was probably changed before I bought the car. is there an inexpensive way to get all of these to match and only have one key? Can the dealer supply a new ignition lock matchng the original key?
Michael
1994 Barcelona Red SVX-LSI
Two-owner:169K
1995 Emerald Green SVX L AWD
#80 - Custom intake w/cone filter
99K with killer stereo system
2002 Acura MDX-Touring Edition w/navigation
2008 Toyota Prius
1987 Mercedes Benz 560SL
Old 02-07-2003, 09:12 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Ignition lock
It would be more expensive to replace the engine ignition switch than to go to a locksmith and have your door locks re-set to match your "new" key.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-07-2003, 09:20 AM
Ignition lock.
My new key works all of the doors and trunk. It matches the factory one based on the VIN. It's the ignition key that doesn't match. Can a locksmith change the ignition tumblers to match the doors?
Michael
Two-owner:169K
2008 Toyota Prius
Old 02-07-2003, 09:41 AM
Aredubjay's Avatar
Re: Ignition lock.
I've never had that done before (sorry, I got your procedures swapped when reading the post -- brain fart. ). Needless to say, I'd think it'd be more expensive to have the ignition tumblers re-worked than to have doors re-worked. Give a locksmith a call and ask em. Info is usually free.
Randy Johnson
