Spark Plug Separator? Help!
Looking for the spark plug wire separator that clips (snaps) on the side of the intake manifold. It's not part #22472KA040 (which I already ordered and returned). These clips are gray and snap into the side of the manifold. Seems as if they get brittle and dry out and break over time. Looked at Subaruparts.com and I can seem to find the correct part #!. Anyone have the correct part number?
You DA Man!! Thanks!
BTW: Those are the rocker covers, not intake manifolds.
![]() KuoH |
wire clips {_}{_}{_} or [_][_][_] for coil wires . . . . . .
Dose are dem arite! I bot em a week igo (kustem ordur!) at da deelur. Had em in a li'l bag. Thru em away 'cus I thot dey wur trash! Jus twenee fighv buks. >>
Heh! Thanks for the good lead for my replacement parts. [Ya know I'll find 'em some day under the sofa cushion!]
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() Last edited by James Scott; 01-24-2003 at 02:06 AM. |
Re: wire clips {_}{_}{_} or [_][_][_] for coil wires . . . . . .
![]() ![]() ![]() Todd
Down to none ![]() |
That's what Subaru calls them.
KuoH Quote:
For the "mature" gentleman, we here at Ronmummertco have developed the Home Hair Transplant Kit. In the comfort of your own home, you can safely and quickly transplant hair from other regions of your body to the most visible of areas. Back getting shaggy? No longer need your OEM earmuffs ![]() If you order right now for the low, low price of only $179.95, payable in 15 easy payments of only $25, we'll include one of our cans of Spray-On Hair at no charge. Perfect for filling in those thinning areas. Todd (any likeness to any board member strictly un-intentional. No- warranty expressed or implied. Spray-On Hair is flammable and will dissolve in alcohol. Avoid smoking or drinking while applying product.)
HAHAHA OMG thats the funneist thing ive seen around here in a while! That made my day. Mike |
Wanna bet it's just a roll of duck tape???
![]() ![]() Todd Best damn duck tape you'll ever find Boone!
