Old 01-15-2003, 05:44 AM
mhl0125 mhl0125 is offline
Send a message via AIM to mhl0125 Send a message via Yahoo to mhl0125
Dash lights again!
Hello,
I hate to beat a dead horse, but I have been unable to find the thread that talks about how to replace bulbs behind the dash. I have a 95 SVX L and one bulb is out behind the speedometer and one behind the "D" on the drive indicator on the dash (not the console). I would appreciate it if anyone could point me in the right direction. This forum has been a terrific help in the short time I have been a member. Thank you all!!
Michael
Old 01-15-2003, 06:32 AM
SuperRuu
there are 3 mabie 4 "cant remember off my head"
under the lip of the dash..
1. remove 3-4 screws holding wood trim to dash..
2. remove the button clusters... (pull one side or other
pull out slightly, grasp tabs on side pull off.... then twist
90Deg one way and put into hole in dash.. (do both)
3. take out screws behind the button clusters.. (2)
4. pull wood trim carefully!! and put on passenger side
of car.. (leaving clock attached)
5. remove (6) black screws holding gauge cluster
(4 corners. 2 above into dash)
6. grab cluster on top pull twards you little bit,
then bottom and it should pop out.. (it has compression connections)
7. find your bulb that's bad, they just twist out like a normal bulb.
but they have a black cap on them.
sorry no picsn right now... hope that helps.
Old 01-15-2003, 06:39 AM
Dash lights again!
SuperRuu,
thank you so much. This is the first solid instructions I've seen. I hope it is not too difficult to do. I will try it as soon as I get some time. Thanks again.
Old 01-15-2003, 06:49 AM
SuperRuu
No prob,
it's not hard, just don't get in a rush and try to force things.
be carefull with wood trim it will snap and scratch easy!!
have fun,
Old 01-15-2003, 08:22 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
go to www.stars-gazer.com/~svx/
there is a DIY area. I have a pictorial how-to on that topic
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 01-15-2003, 10:31 AM
Dash Lights Again
Thanks Seraph,
That's a terrific job with all the pics...I hope I don't break anything in the process.
