Old 05-03-2019, 10:47 AM
shotgunslade's Avatar
Mystery Warning Light
Does anyone know what is the meaning of the red warning light that is on the row of controls immediately below the instrument cluster? On a left-hand drive car, it is immediately to the right of the steering column and to the left of the rear window defrost switch. It is on the left in the attached photo
File Type: jpeg 3483483E-2DC5-4559-B630-4C91B16F9162.jpeg (928.5 KB, 187 views)
Old 05-03-2019, 11:05 AM
Re: Mystery Warning Light
Dan
That is not factory light. Nothing was ever installed there. Blank panel (maybe used on the RHD Markets.
Aftermarket LED installed.
Could it be for power to an auxiliary circuit or an indicator light for an aftermarket system?
File Type: jpeg 9EC224A5-B3CA-49B1-9365-D9764B1B4BFD.jpeg (31.3 KB, 299 views)
Old 05-03-2019, 11:23 AM
Yep. It’s on my Emerald, an there isn’t one on my red. Have reached out to Young Tom. He must have added it. May be related to my Hydra.
